Help Kohler 8 hp
   / Help Kohler 8 hp #1
Mattc8832
West Virginia
John Deere 3032e,Snapper Pro SW20 and s200, Stihl Handhelds, BCS 830, Yamaha Rhino 700, 2 - Gravely 5260, New Holland LS 45 , 6,10 by 14 Trailer , Woods BH 6000 Towable Backhoe, Honda 21 Self Propelled, Exmark Commercial 21and shop full of tools
I tore down the kohler 8hp well I only too the head off and the piston and rod out. I installed new gaskets , piston , rod and rings. I didn't remove the cam , crank or valves. Once I removed the piston and rod I turned the crank a couple of turns not thinking them I assembled a new piston and rod and put the engine back together. Cold I have the valve timing off by turning the crank. I believe both valves were closed when I installed the new piston.
   / Help Kohler 8 hp #2
As long as you didn't un-mesh the gears, you didn't change valve timing.
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53473)
NEW HOLLAND 706 30...
2024 Wanco WCTS-SM4A-730 800W Solar Integrator Trailer (A51691)
2024 Wanco...
Truck Wheel Fenders (A51692)
Truck Wheel...
(INOP) JLG 36AM-DC VERTICAL MANLIFT (A51247)
(INOP) JLG 36AM-DC...
(2) VISSANI REFRIGERATORS (A51248)
(2) VISSANI...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
