Help: John Deere 4000 series handle question
   / Help: John Deere 4000 series handle question #11
Eric
Can you tell me where you bought the switches from and maybe a part number?
Thanks
Regards
Jeremy
   / Help: John Deere 4000 series handle question #12
Are the plastic hand grips available separately?
Mine is cracked and the previous owner taped them together.
Also... the stick is sloppy... best guess is it was forced with the lock on.
Everything works so I have not delved into making it a priority repair.
   / Help: John Deere 4000 series handle question #13
These are the part numbers (as posted elsewhere on the forum), you can look them up in JDP as well:
   / Help: John Deere 4000 series handle question #14
Thanks Kenny D... Just what I needed.
   / Help: John Deere 4000 series handle question #15
OK folks - are all relays for this handle created equal. My JD dealer indicates that the wiring harness plugs into a very expensive relay and fuse block that uses AT 308380 micro relays. This part number crosses over to a 280-SAE J1744 relay. Is there something special about this relay - its expensive. Is it matched to the switch . I cant seem to find any particulars on the grip switch or the switching load in the relay. Thanks for any education you can giv me. I have shorted out to many device in my lifetime so far :confused3::laughing:
   / Help: John Deere 4000 series handle question #16
I guess I wasted my time in all the PM's I resounded to. Thanks.
   / Help: John Deere 4000 series handle question #17
Sorry Kenny I did not know you responded. I'm not getting notifications. When I click on the alert icon is indicates no new message even though they are there. I found what you said - thanks for helping.
When I found the JD relay number that went with the grip, I was curious if it was something special. Ill just use what you recommended.
Thanks again
Hose Reel (A55787)
Hose Reel (A55787)
2006 Ford Taurus SE Sedan (A54815)
2006 Ford Taurus...
(INOP) 2024 ATLAS CORPO PACF44 DEWATERING PUMP (A52707)
(INOP) 2024 ATLAS...
2016 Kubota SVL75-2 (A53317)
2016 Kubota...
Honda EM3500S Portable Gasoline Generator (A55851)
Honda EM3500S...
Ford 8510 (A53317)
Ford 8510 (A53317)
