Help John Deere 320 Kawasaki Engine Won't turn over
   / Help John Deere 320 Kawasaki Engine Won't turn over #11
That fixed it! Thanks everyone. Now to figure out why the oil filter seams to leak oil.
Not tight enough, or too tight. :)
Or the seal is messed up, or has dirt under it. Not much else to go wrong, as long as there isn't a hole in it.
Glad the cable connections are ok now, and you are back in business. Looks like a good snow clearin rig.
   / Help John Deere 320 Kawasaki Engine Won't turn over #12
..... Now to figure out why the oil filter seams to leak oil.
Just had this happen on my '08 GMC pickup truck. Replaced the filter and all is fine now. I've also seen where the rubber seal from the old filter stuck to the engine and new filter was put on over the old seal causing leak.
   / Help John Deere 320 Kawasaki Engine Won't turn over #13
Did you lube the gasket on the new filter with clean engine oil before installing? If not, possible that the gasket bulged up a bit when filter was tightened.
Not the oil filter. I posted a question for help. This little gadget is where the leak is occuring
   / Help John Deere 320 Kawasaki Engine Won't turn over #15
Oil pressure sensing unit? Maybe just needs tightened.
CATERPILLAR SKID STEER QUICK ATTACH PALLET FORKS (A51243)
CATERPILLAR SKID...
2012 MACK PINNACLE CH613 FLAT TOP DAY CAB ROAD TRA (A51243)
2012 MACK PINNACLE...
2017 Chevrolet Express 2500 Cargo Van (A50323)
2017 Chevrolet...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2020 Kubota Sidekick RTV-XG850 (A47384)
2020 Kubota...
Quick Attach Pallet Forks (A47384)
Quick Attach...
