Help!! JD1070 - Engine Dies When Engaging PTO in Gear
   / Help!! JD1070 - Engine Dies When Engaging PTO in Gear
Just glancing over the wiring diagram. The seat switch has three positions. On - Off - Defeat. Make sure the seat switch is in the on position instead of defeat.
Dumb question here: what is the purpose/function of the "Defeat" position?
   / Help!! JD1070 - Engine Dies When Engaging PTO in Gear #12
Its so you can run the tractor with pto on nobody in the seat. Also on my jd770 the dealer said to run the trans in second gear with high low range in neutral when using the backhoe to lube all the trans gears
Got it, thanks!!
   / Help!! JD1070 - Engine Dies When Engaging PTO in Gear #14
Also if you need the black box I have one that's good you can have it should fit, mine was a 1992 jd 770 just pm me:)
Thanks to all who assisted with this issue. It turned out to be the simplest of problems, as they often are. The seat switch had gone bad--it didnt matter if it was up, center, or down, a multi-meter proved that it was sending continuity on the "defeat" pins. After removing it and jumping the 1/3 wires, everything works as it should!!
2000 Thomas Built Saf-T-Liner MVP-ER Transit Bus (A55852)
2000 Thomas Built...
2014 Ford Fusion SE Sedan (A53424)
2014 Ford Fusion...
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A55851)
2025 Kivel 42in...
(4) ELECTRIC MOTORS (A54757)
(4) ELECTRIC...
2020 KENWORTH W990 TRI AXLE DUMP TRUCK (A54607)
2020 KENWORTH W990...
2015 Komatsu PC138 (A47477)
2015 Komatsu PC138...
