Help! it won't start!
/ Help! it won't start! #1
SteadyEddie
Hudson Valley, New York
Kubota Bx2350
I could use some advice troubleshooting this problem. I have a 1 yr old, garage kept Bx2350 that suddenly wouldn't start. It was fine when I backed it out, turned it around & backed in for "winter prep". The only things I did were to plug a light kit (from Bxpanded) into the work light connection (left rear) & installed the ballast box. When I hit the key to pull out - nothing! There's no cranking at all.
Here's what I tried so far; battery tested @ 12.5v, connections are clean & tight. Checked all fuses in block (& "slow blow" by engine), replaced the 10a "solenoid" fuse ("just in case"). The brake is on & the pedals are "in neutral".
Could this be the starter? My dealer is closed 'till Monday & we're supposed to get our first snow tonight (of course!). Any thoughts would be greatly appreciated!
/ Help! it won't start! #2
Do your dash lights work when you turn on the key; check your operator presence switch under the seat?
Yes, the dash lights come on, & that "clicking" sound when it's @ the glow plug setting. I made sure the operator presence switch was firmly plugged in, but I've been able to start it while standing next to the machine in the past.
/ Help! it won't start! #4
...and if there is a PTO then check to see it is in the disengaged position. I have been bit by that a couple times.
Also see if you can jump it by bridging power to the solenoid. If that doesn't start it up then the solenoid may be a gonner.
Pat
/ Help! it won't start! #5
Pat
My first thought! Once in a while I have to pull extra on the PTO lever to "seat" it.
Deano
/ Help! it won't start! #7
Hold your key in the start position and rock your HST forward /reverse pedal back a forth a bit. sometimes the switch doest meet make when its centered. If this is the case as you engage the switch it will turn the starter.
/ Help! it won't start! #8
Sounds like one of the safety interlocks is acting up. On mine, it's usually the PTO engage...
/ Help! it won't start! #9
I'll vote for the PTO engagement lever not quite being seated as well.
Mine is sensitive. Driving the tractor across bumpy parts of my yard or brushing it with my clothes can cause brief what the ?! moments. A quick tug on the lever and all is well.
Thanks for all the advice so far!
I haven't tried bridging the solenoid yet (I've always been a little chicken about that), but I'm beginning to feel it's one of the safety permissives. When I was trying to remove the cowl, I noticed a green wire hanging free & what I believe to be the water temp sensor without its wire. After I plugged it in, something said to give it a try. The starter cranked fine! I buttoned everything up and sat on the seat & tried again - nothing! What I'm thinking is one of the permissive switches is hanging up & I bounced it back to its "no start" position when I climbed on. As far as the battery, I did try to jump it with one of those power-packs with no luck. I will try a trickle charge for awhile though, it sure couldn't hurt!
/ Help! it won't start! #11
Just for giggles have you tried removing the work light and ballast box that you orginally installed just to see if it makes a difference? I only jump the starter as a last resort. I agree it does sound like a safety switch has tripped somewhere. Allthough if you are getting juice to the starter but... maybe the pesky engine kill switch :rolleyes:
Pdseifert, I did disconnect the work lights (but not the ballast box) - no luck. Logic told me from the beginning that the lights weren稚 to blame, but it was still the first thing I did!
/ Help! it won't start! #13
3 things to start with that I'v got cought with
hst in neutral?
pto not in gear?
foot resting on hst petal or it was sticky and not in center?
tom
/ Help! it won't start! #14
wait- you didnt sit on it (not sure if you did this or not) when you found the green wire and plugged it in and cranked engine ? then put everything away and sit on the seat and it dead ? did you try standing on ground and start it with nothing in seat ? sounds like a seat switch issue.
/ Help! it won't start! #15
Many have mentioned it but I will again. Look real hard at the various safety cutoff switches. That's almost certainly your problem. The fact that it started without weight in the seat then didn't when you sat down only confirms it to me. There's a complex set of rules regarding what switches need to be in what position for things to run properly. The rules change depending upon whether or not your butt's in the seat.
I've been burned by both the seat switch and the PTO lever. The PTO lever was particularly confusing because, even though it was in the correct (disengaged) position, I needed to give it a firm push to fully engage the switch.
/ Help! it won't start! #16
I suspect the pto shutoff too. Get underneath your tractor and follow the cable from the pto lever to where it connects to a lever on the transmission housing, it should be on the right hand side if you were sitting on the tractor. With your fingers see if you can move the lever forward, toward the front of the tractor. If it moves then you have found your problem and should be able to adjust the cable.
/ Help! it won't start! #17
For some reason I thought the safty switches only cut off power to the fuel solenoid. I thought the engine would just stall or not run but would still crank over. The one exception is the clutch needs to be pushed in. Am I wrong?
Rob
Ok just check my work shop manual on the b3200, should be similar on your tractor. According to the manual the only time the engine will not crank is when pto switches are engaged or hst pedal is not in neutral. Seat switches play no roll in cranking.
/ Help! it won't start! #18
Rob
you know- as I sit here and thought about what you said- it seems you are absolutely right about that with my BX as well. I am thinking about making a laymans troublshooting chart for starting the BX's BEFORE the tractor decides to quit.
THANK YOU! THANK YOU! One & all! It turned out to be the PTO safety interlock. The lever was fully seated but...
Your help saved me at least $300.00 for the dealer to come & look at it. They charge the hourly shop rate PLUS a mileage fee to come to your site and it痴 not waived for warranty work. Now the business man in me understands, but I wish they had given me ALL the facts before I purchased. Well, lesson learned, and my wife has agreed that I should move up the timeline to get a trailer for the 'bota!
/ Help! it won't start! #20
Rob
Wish I had thought of that. I have a couple of older model tractors and to start them, you pull a cable for the fuel pump and then hit the starter. To kill it, you must shut the fuel off as turning the key off does nothing but kill the electrical system.
2027 . 500k BTU Wellhead  Heaters (A67714)
2027 . 500k BTU...
2017 KENWORTH T880 (A67714)
2017 KENWORTH T880...
Case SV300 High Flow Compact Wheel Loader Skid Steer (A66734)
Case SV300 High...
2019 Ford F-450 Knapheide Service Truck (A66736)
2019 Ford F-450...
Unused 2021 IDeal RC6MD 6ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2021 IDeal...
500BBL WHEELED FRAC TANK (A67714)
500BBL WHEELED...
