Help identify this tractor
   / Help identify this tractor #1
wickedardvark
Concord, GA
Kubota L245 & Allis-Chalmers B
Picked up this old tractor recently. Previous owner says its a '73 or '74 Farmall Cub. I can't find any identifying markings on it and wanted to see if any of you Farmall experts can confirm. Thanks!
   / Help identify this tractor #3
I can't tell you exactly what year, but a 73 or 4 cub would have much different sheet metal. Much more square in appearence. Ck on YTMAG.com, the farmall boys there will set you right.
   / Help identify this tractor #4
What you have there is a Allis Chalmers B. Look to the right of the shifter, the serial number is cast into the trans casting around there.
   / Help identify this tractor #5
The A-C B models were built from 1938 to 1957.
Thanks everyone for the replies. I guess the fellow I got it from didn't know what he had! Doesn't bother me at all. Maybe one day it'll look like the one in that picture Rick! By the way, will the serial number allow me to tell what year model it is?
   / Help identify this tractor #8
1938: 97
1939: 11800
1940: 33502
1941: 49721
1942: 56782
1943: 64501
1944: 65502
1945: 70210
1946: 72265
1947: 73370
1948: 80556
1949: 92295
1950: 102393
1951: 114527
1952: 118674
1953: 122310
1954: 124201
1955: 124711
1956: 126497
1957: 127186
Final: 127461
1946: 1001 (IB)Idustrial
1947: 1003 (IB)
1948: 1010 (IB)
1949: 1282 (IB)
1950: 1556 (IB)
1951: 1879 (IB)
1952: 2219 (IB)
1953: 2570 (IB)
1951: 4001 (EB)English
1952: 6861 (EB)
1953: 9200 (EB)
1954: 11120 (EB)
   / Help identify this tractor #9
Google A-C Model B and you will find several antique tractors site with a lot of Information.
   / Help identify this tractor #10
They are beauties.
Thanks guys for all of the info. I really appreciate it!
Found these numbers on the outside of the transmission casing. They don't seem to match any of the ones listed above. Any ideas about year model?
   / Help identify this tractor #13
Thats not the serial. Its on top of the transmission casting about 2 inched back from the shifter. It will be a slightly raised rectangle. The numbers are inside of it. Might need to be wire brushed to see the numbers.
Ok, found it. See what you guys think.
   / Help identify this tractor #15
Its serial #B120353. So that makes it a 1952 model.
Got it Mike, I see how that works now. Thanks for all your help!
Brad
   / Help identify this tractor #17
This is a great site!
I've been visiting regularly for several years now and it never ceases to amaze me how much knowledge there is out there and how quickly it is exchanged. I'm sure that the OP could have gotten to the same place by a lot of on-line 'digging' but we are truly blessed to have this 'community' to learn from. Well done.
Frank
UNUSED RAYTREE REDM32 HYD MULCHER (A60432)
UNUSED RAYTREE...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
2006 CATERPILLAR 420E BACKHOE (A59823)
2006 CATERPILLAR...
2015 Toro Sand Pro 5040 Bunker Rake (A59228)
2015 Toro Sand Pro...
Tug Boat with Tri Axle Magic Tilt Boat Trailer (A59231)
Tug Boat with Tri...
2015 CATERPILLAR 308E2 CR EXCAVATOR (A60429)
2015 CATERPILLAR...
