Help Identify Ford Industrial
/ Help Identify Ford Industrial #1
Jimmike44
Raleigh, NC
1963 Ford 2000 Industrial
So I am brand spanking new to the tractor world! I have recently purchased on older Ford tractor, that after hours of research, I believe is some type of industrial model. I am attaching a picture of my tractor. There are 2 different rear wheels on this tractor (as I figured out after I bought it!), the other side has a disc that is mounted to the rim in 5 or 6 spots (can't remember right now).
I am attaching pictures of some of the numbers I have been able to locate.
The most important picture (I think) is from the flat spot near the starter. What I have been able to determine, is that the is a "4" turned perpendicular to the other numbers. Then near the edge is a "4441" stamp. Directly above that appears to be "21305". However, the "5" seems to be stamped on top of a "2" and also the first "2" appears to be stamped over something that I can't make out.
I don't have a picture with me, but I believe there is "CONN 6015G" on the right side of the engine.
There is also what looks like an "F" inside of a "C" logo, followed by "2D9" on the engine.
There is a Ford Loader mounted on the tractor, appears to say "I9-201" and serial "5384" on the ID plate.
There is one shifter lever mounted in front of the seat. I believe I have reverse and 3 forward speeds. It has 3-pt and PTO. The front axles are not adjustable. It is a gas engine. It has power steering.
I will attach as many pictures as I can.
/ Help Identify Ford Industrial #2
:welcome:
To the TBN forum. You came to the right place to get answers.
So which is it, Jim or Mike?
It does look somewhat like an old industrial tractor but I am not completely sold on it.
/ Help Identify Ford Industrial #3
Welcome to TBN. Good luck with your Ford!!
/ Help Identify Ford Industrial #4
You have a light industrial 2000 1962 with a 134 sleeveless engine. It's a 4 speed. look for the numbers on top of the tranny shifter cover. Looks like the rear might have been changed out to a late 801 or 4000 rear.
It's Mike ;) Combination of my first and middle names, a nickname given me during the academy because there had already been a Jim and a Mike introduced in the class.
:welcome:
/ Help Identify Ford Industrial #6
Hi guys, I'm new to this site and new to owning a tractor....
I bought a ford 3400 with loader
the identification numbers are
4k14B
C439484
Could anyone tell me what year this tractor is?
Thanks in advance
/ Help Identify Ford Industrial #7
Your 3400 tractor was built October 14 1974 day shift.
By the way, Ford built Ag, Utility and Industrial models on that same basic platform. A 3400 is a Utility model. Not an industrial.
All are very good machines.
/ Help Identify Ford Industrial #8
I too would like help identifying my recently bought old ford industrial tractor.
Here are the numbers that are legible: near the starter - 3BC85 - hard to see, may not be correct, below that number is *C372129*, on other side of engine is 2M19C, below that is T70A14. My research has resulted in much confusion.
