Jimmike44
So I am brand spanking new to the tractor world! I have recently purchased on older Ford tractor, that after hours of research, I believe is some type of industrial model. I am attaching a picture of my tractor. There are 2 different rear wheels on this tractor (as I figured out after I bought it!), the other side has a disc that is mounted to the rim in 5 or 6 spots (can't remember right now).
I am attaching pictures of some of the numbers I have been able to locate.
The most important picture (I think) is from the flat spot near the starter. What I have been able to determine, is that the is a "4" turned perpendicular to the other numbers. Then near the edge is a "4441" stamp. Directly above that appears to be "21305". However, the "5" seems to be stamped on top of a "2" and also the first "2" appears to be stamped over something that I can't make out.
I don't have a picture with me, but I believe there is "CONN 6015G" on the right side of the engine.
There is also what looks like an "F" inside of a "C" logo, followed by "2D9" on the engine.
There is a Ford Loader mounted on the tractor, appears to say "I9-201" and serial "5384" on the ID plate.
There is one shifter lever mounted in front of the seat. I believe I have reverse and 3 forward speeds. It has 3-pt and PTO. The front axles are not adjustable. It is a gas engine. It has power steering.
I will attach as many pictures as I can.
