Flail Mower Help ID this flail mower
/ Help ID this flail mower #1
docrocky
NW Ohio and SE Michigan
Oliver 880, Ford 8N, Ford 9N, Farmall Super C, MF 205, Ford 4400 FEL, Ford 4500 FEL/BH, Cat D-6 Dozer(1957)
I bought this flail mower several years back from a friend who buys and sells old equip, he bought it at Archibold, Ohio auction. All ID plates are missing . It is 91" wide with 80"cut. It is offset 60" by 32". Only remote ID is it is painted Ford blue over Ford industrial yellow. It has 4" T cutters, 26 per row and 4 rows. What makes me think it is a Ford is the shafts are 11/8". Prior owners welded a female spline to the drive shaft and this totally wore down. I took it apart last year but no machine shop around NW Ohio can replace the female spline. I found the right spline size at TSC but it that ?yellow cast metal from India and I tore one up before hooking up a Ford PTO to larger yoke. I now am seeking a schematic to help reassemble the components. I have replaced the bearings which were destroyed. I will attach photos in hope that some one can ID this for me. Is it a Ford 907 or possibly a 917? Am looking for schematic to help me put it back together, if possible.
/ Help ID this flail mower #3
Check with the local Ford New Holland Farm Equipment Dealer
in your area and I am sure they can help you.
If there are no local Ford New Holland dealers in your area I would call www.wengersofmyerstown.com and I am sure they can help you.
We have lot of Ford Flail Mower owners here too and they are always willing to help folks with flail mowers.
I offer a big welcome to you as our newest member the Flail Mower Nation.
_________________________________________________________________
Once you go flail you never go back:thumbsup::licking::drool:
/ Help ID this flail mower #4
I would have to see a female spine that a machine shop can't reproduce!!! My thoughts are "don't want to reproduce that spline" since it is a one off and probably not a lot of money in it for them. Just too much trouble to set up a machine to do a single job with limited payout (tractor parts typically don't pay well to reproduce). My thoughts are if you can't find the part, either find a machinist that likes tractors or replace both sides of the spline with a new piece welded on to each end.
David from jax
David from jax
2017 Case CX145D (A62177)
2017 Case CX145D...
Bobcat 873 (A55272)
Bobcat 873 (A55272)
UNKNOWN  500BBL FRAC TANK (A58214)
UNKNOWN 500BBL...
2012 MACK CHU (PINNACLE) (A63569)
2012 MACK CHU...
2023 John Deere 8R 370 Tractor (A63109)
2023 John Deere 8R...
generator trailer (A61569)
generator trailer...
