HELP! Flat tire, now what?
/ HELP! Flat tire, now what? #1
ctgoldwing
Platinum Member
Central Connecticut
L3800HST
I just finished 1-1/2 hours of great seat time clearing scrub trees in the woods with the FEL. As I was backing into the garage the machine just sagged down. It was obvious I had a flat & sure enough my left rear was down. I lifted the machine by the bh outriggers & the tire is broken away from the bead. Is there any 'trick' to getting the bead to seal while I put air into it? I have about 90 psi available but the gap between the tire & wheel is just way too much. Horsing these R4's isn't very easy. . .
Am I reduced to calling a tire company?
/ HELP! Flat tire, now what? #2
Do a search for " bead seating" in all forums and you will get plenty of ideas.
Bill
Bill
Thanks! much better results than searching for "tire" :)
The ratchet strap sounds like a winner! I can't imagine what happened other than perhaps a rock broke the bead & I lost most of the air in the woods & then it just let go as I was backing in. . . weird.
Thanks so much (I wasn't looking forward to pulling it off & schlepping it to a tire dealer)
/ HELP! Flat tire, now what? #4
Ratchet straps work well on smaller tires, I've never used them on bigger stuff. On tires like those on a "dolly" or wheel barrow, wrapping the tire with several turns of black tape under the most tension it will handle will also work.
I've also used the ether method on very stubborn larger tires.
The vid is a little more safety oriented than what I do, but it shows the principle. Keep water handy, as whatever you overspray will burn. Don't get you face or body inline with the outer face in case the tire coms over the bead, which I doubt will ever happen. If the tire is dismounted, it may jump off the ground a bit.
Greasing the bead also helps get a quicker seal.
Check what the propellant in the ether can is, some use CO2, which slows the burn. Also makes it useless in spud cannons!
E
/ HELP! Flat tire, now what? #5
Twice so far on my NH TC-29 I have broken the bead on the left front tire ..once bush hogging on a hill side and another time with a load in the FEL and both times I let my small 30 gal air compressor get full and then shot the air to it and the bead sealed and no problems..I was surprised myself but it was just that easy..it takes some fast air pressure with mine and all is well.
/ HELP! Flat tire, now what? #6
Some day I may also build a "bead blaster" which is made from a 20lb propane cylinder. Charge the tank and put a 1.5" ball valve on it. (Obviously not in that order! Then there is a nozzle shaped sorta like a wide wet/dry vac end and set it next to the bead. Flip the valve and KABOOM!
With air cannons, I've used 3/4" electric sprinkler valves for quick air release. I'd have the only battery operated bead blaster!
/ HELP! Flat tire, now what? #7
So how in the heck can you work on a propane tank, even if it empty? I heard of people cutting it, welding it, but it just plain scares me. What can you acutally do to make it safe to work on?
/ HELP! Flat tire, now what? #8
Purge the tank with argon and go from there. Argon is an inert gas and should improve your comfort factor.
/ HELP! Flat tire, now what? #9
We use nitrogen...
As for the flats... after having 3 different work dates interrupted by flats... I went ahead and had my tires foamed filled and no problems since...
/ HELP! Flat tire, now what? #10
There is a tire soap that looks like lard. You slather it on the rim to seal between the tire and the rim. As you're filling the tire you would scrape the soap off and put it back in the bucket. Stuff lasts forever and you don't need a large amount.
Good luck
/ HELP! Flat tire, now what? #11
If you are able to take the weight off of it leaving it that way and rolling the wheel may find it settles onto the rim or if you have a helper one may be needed. There is another way, tube.
/ HELP! Flat tire, now what? #12
Only time I've worked with propane cylinders was to make "pig" lawn ornaments from them. Just removed the valve, purged with compressed air and let it sit upside-down over night, and welded away.
My eyebrows grew back within three weeks..... Just kidding.
/ HELP! Flat tire, now what? #13
LMAO:D
/ HELP! Flat tire, now what? #14
The last comment is scaring me even more :eek:. kidding!:D Now I remember from my CERT training propane is heavier then air so turning it upside down "should" help :rolleyes: . I just don't have access with argon, just air from my compressor.
/ HELP! Flat tire, now what? #15
/ HELP! Flat tire, now what? #16
1. If you take the valve off, the liquid propane in the tank will quickly vaporize and you will be left with nothing but gaseous propane.
2. You can purge this with air because the volume is very low and there can't be much of an explosion in there. If you don't feel safe doing this, fill the tank with water which will displace the propane gas. Drying the water out afterwards is going to be a PITA.
Do not try this with gasoline. Fuels which are liquid at room temp and pressure are a lot harder to get rid of.
/ HELP! Flat tire, now what? #17
Lots of inert gases available to purge a propane tank but due to $ I'd go for CO2. One easy way to get CO2 if you don't have it handy is Dry Ice (Wally World or ...). Filling with water is a good option. To get the water out just put in some "Heat" or other water removing/dispersing fuel additive. Acetone works well too. Just put in THE STUFF, slosh it around to mix with water really well and dump it out. Residual acetone will quickly evaporate.
I have used really strong rope to make a tourniquet around the tread with a strong stick or tool handle or tire iron for a handle to seat a bead successfully a few times. Following episode was preceded by that approach but failed.
A Mexican tire shop had the tank with big valve but couldn't seat the bead on a new tire for my motorhome. Not having starting fluid/ether they used gasoline. I watched from a little distance. Took 4-5 tries but eventually worked. Stiff tires are a pain.
Pat
2018 Kubota M5-111 (A60462)
2018 Kubota M5-111...
(INOP) 2006 FORD F-150 XL EXT CAB (A59823)
(INOP) 2006 FORD...
1997 DACO TRAILER 48-FT FLATBED TRAILER (A60736)
1997 DACO TRAILER...
2024 OMEGA 2700S WHEEL LOADER (A62129)
2024 OMEGA 2700S...
2018 SPORTSTER BUMPER PULL (A60736)
2018 SPORTSTER...
Freighliner Tender Truck (A61307)
Freighliner Tender...
