Help finding small, single drop axle, low deck trailer
   / Help finding small, single drop axle, low deck trailer #21
Take it from an old Dude who has hauled antique motorcycles all over the country...go for a dual axle trailer, even if you have to save a bit longer to get it. It is only a matter of time until you blow a trailer tire and the security of having the second axle is worth the extra money. Buy high quality tires, keep them properly inflated and protected from sunlight when not in use. Invest in "Bearing Buddys" and keep them lubricated with Saltwater proof wheel bearing grease, available from marine stores, as it will not emulsify if any water gets into the bearing. I'm speaking from experience, I-95 near Savannah, single axle box trailer with $50,000 in antique cycles, tires were checked upon leaving Maryland and looked great, big bang, something flew past the drivers side of my Avalanche, it was the left trailer fender and the trailer started the Texas two-step. Lucky me, I got it off on the shoulder and all was well. I bought two new tires in Savannah and when I returned to MD, I bought a tandem axle trailer.
Wow, thanks for all the responses! I'm very happy to have everyone's experience in front of me. I'll try to answer questions and respond to comments (many of these thoughts are interrelated):
Hitch ball size: this is not a big deal, it's just that the 4 trailers I tow today, from time to time, all have 2" balls, so it's just simpler. As far as I can see, the weight rating is not exactly related to the ball size, but rather to the ball shank size, and the capacity of the ball mount and hitch itself. I'd most likely be looking at a 7000 pound GVWR, so would make sure that all that is of the appropriate capacity.
Tow vehicle: this may vary - right now it's a Ford Expedition, but at some point in the trailer's lifespan may be something smaller.
Tilt bed: I was originally looking for a tilt bed, not so much for loading the tractor, but rather for dumping loads of brushwood. I currently use a much smaller tilt trailer, and it's convenient to just unclip the tilt latch, and at least some of the time the wood unloads itself as you drive forward. I have come to realize that with a larger trailer, the tilt will be nowhere near as steep as the one I am used to, so it's not going to help with unloading. And since I decided against tilting, that got me to the drop axle idea, for lower center of gravity and easier loading with ramps.
Dual vs. single axle: I was originally thinking single, because lots of companies make single axle tilt trailers fairly inexpensively. Dual axle tilts seems to cost quite a bit more as the tilt mechanism is more complex. Another factor was weight - all other things equal, fewer axles would be lighter, even though axle for axle the heavier single weighs more. But I do think the duals give a margin of safety on the road, and I will be towing approximately 200 miles at a shot.
Size: the size issue isn't so much one of cost, but rather where to store the trailer when I am not using it. The place I have to keep the trailer is actually more constrained by width than by length, though. I actually toyed with the idea of a 60" width, both for reasons of storage and because the roads I traverse to get to the brush dump are pretty tight. But I think a 60" by 14' trailer would be just goofy, plus the extra width does contribute to towing stability. I do agree that since my tractor and loader are just about 12 feet long, a minimum of 14 feet are important to give myself some room to balance the load. Also, increased size means more weight and thus less payload. Still thinking on this one.
Customizations: I agree that many of the add-ons can be added on (d'oh) or modified later, as long as I get the basics right. Flush lights would not be so easy to add, which is one reason I'm leaning toward PJ Trailers, which has the lights built into the rear crossmember.
Ditch-witch type single-axle, tilt trailer: I like the looks of these, including the ones made by CAM Superline and Ditch Witch themselves, but they are awfully proud of them. And rightly so, they seem to be great units, just overkill for what I need.
One other question: most of the manufacturers, including PJ, offer an option of more closely-spaced crossmembers -either on 16" or even 12" centers (I assume the stock is 24"). I am thinking this is a good thing, even though it will add weight. Your additional thoughts are appreciated.
Thanks again all!
Tim
   / Help finding small, single drop axle, low deck trailer #23
I think you have good reasons to choose a non-tilting trailer. I'm still putting my pitch in for the tilt deck. It won't help you unload brush, but it makes loading and unloading vehicles VERY nice. You can always not tilt it.
Now I'm going to contradict myself... If you're planning to pull this trailer with a smaller vehicle, weight will be your enemy. I think you have good reasons to avoid any excess length. Tilt will also add a little weight to the trailer as will additional cross members.
From all the info you given us, I think you have made the best decision to go with a 14' trailer.
One last note about the flush lights... they aren't as hard to add as you might think. Use a good hole saw to cut the hole and pop in some round gromet lights. Voila! You're done.
You are quite right on the lights - a quick look at etrailer.com even found me flange mount (surface mount) lights which would just require a few screw holes. Thanks for mentioning that - it opens up some options.
Tim
2018 CATERPILLAR 336F L (A58214)
2018 CATERPILLAR...
JOHN DEERE 544G WHEEL LOADER (A58214)
JOHN DEERE 544G...
2018 Chevy Silverado 1500 4X4 (A56438)
2018 Chevy...
SUV (A59231)
SUV (A59231)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
