Help Finding a Switch
   / Help Finding a Switch #11
Does your tractor have any blank holes where you can install a factory switch? My Case DX35 had some blanks where I could put a factory switch for an LED light bar.
   / Help Finding a Switch #12
I would not use that switch in a application like yours. You need a switch with the seal on the toggle lever. Moisture will get in there a ruion the switch in short order.
As someone else said, is there another place you can put the switch ? Or drill a new hole in the dash for your switch.
You will want on like this:
Cole Hersee 55021 Standard Heavy Duty Metal Toggle Switch w/ Sealing O-Ring, SPDT, 25A​
From here: Cole Hersee 55021 Standard Heavy Duty Metal Toggle Switch | Waytek
But there are lots of sources for these switches. Maybe even your local ACME surplus store.
   / Help Finding a Switch #13
If you need anything special in switches, your first stop should be Digikey and Mouser Electronics. Their search filters allow you to narrow down what is important to you and they have thousands of options.
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A55973)
2017 Chevrolet...
CASE IH MX220 MAGNUM TRACTOR (A58375)
CASE IH MX220...
1996 Sunflower 1543-38 Folding Disk (A56435)
1996 Sunflower...
More info coming soon! (A55787)
More info coming...
2013 Fiat 500 Sport Hatchback (A56859)
2013 Fiat 500...
