Help figuring out fitting
/ Help figuring out fitting #1
mrfu
Shasta County ,CA
Mahindra 2615
Hi all
I have a hydraulic fitting off of a chinese wood chipper. The female end is jic 3/8 the male end is odd it is 17.75 mm in diameter. The guy at the hydraulic place couldn't figure out what it is. it is a straight thread with no taper pitch if metric is 1.5 or if english or 20 tpi if english.
It also uses a bonded washer.
Any ideas or is it within the specs for an 18mm fitting.
I am getting a fitting from the place I bought it from it would just be nice to have another source
Thanks
/ Help figuring out fitting #2
Could be M18x 1.5 or Possible that it is G3/8 - 3/8-19 BSPP British Straight Parallel Pipe thread. G3/8 should be around 16.5 -17 mm OD They both can use a bonded seal washer
Thanks for the help. I ordered one of each, but I have a feeling it is m18 x 1.5 just with sloppy tolerences
Tom
/ Help figuring out fitting #4
I am going to agree M18. .25mm is less than .010" probably a little undersize, but works.
Thanks everybody for the help. it turned out to be an 18mm fitting
Tom
KingKutter XB (A64126)
2020 GMC AT4 CREW CAB TRUCK (A65054)
2020 GMC AT4 CREW...
(2) 30 Yard Roll Off Dumpsters (A65579)
(2) 30 Yard Roll...
2019 Dodge Charger Sedan (A64557)
2019 Dodge Charger...
2015 Kubota SVL 75-2 (A64126)
2015 Kubota SVL...
Kubota L175 Tractor (A62613)
Kubota L175...
