Backhoe Help attach bl4690 backhoe to b7800 tractor
   / Help attach bl4690 backhoe to b7800 tractor #1
VaJim
Richmond Virginia USA
Kubota B7800
I’m having trouble mounting the backhoe – the top hole in the top link at the tractor does not line up - too far toward the tractor /forums/images/graemlins/confused.gif. I bought the b7800 tractor used last month, the backhoe this month. The backhoe came off a b7800. I don’t have the reinforced top link connector on the tractor yet. The backhoe instruction book does not mention the b7800 specifically, but the backhoe appears to be set up for a b2910. Any suggestions?
Also, I considered rearranging the top arm but the bolts don’t budge for me. What does it take to work these (about 36mm aircraft bolts)?
   / Help attach bl4690 backhoe to b7800 tractor #2
Jim,
I have a B2910 with a BL4690B - I would not run the 'hoe without the reinforced toplink bracket - Kubota puts it there for a reason. I can tell ya for sure that the toplink bracket does take some very significant stresses.
It also could be that the reinforced toplink bracket has the holes in a slightly different position that the regular one which would allow it to mount correctly - dunno on this, I never checked it personally.
And I believe if the 'hoe was configured for a 2910 when it was assembled it should work fine on your B7800.
   / Help attach bl4690 backhoe to b7800 tractor #3
There is a difference between B2910 & B7800 setup. Here is a thread that discusses the problem.
Click Here
Please do not operate your BH without the heavyduty top-link bracket. This could be a very expensive mistake if the rear housing of your B7800 failed.
Thanks Randall and Ron for your replies. I missed the thread Ron mentions when I searched before posting. That thread suggests the mast should be set up like a B2710, which makes sense just eye-balling it.
Now I need to find some real tools to handle the 400-500 ft. lbs. torque on the 7/8in. fasteners.
Thanks again!
2022 Ford Escape S AWD SUV (A54815)
2022 Ford Escape S...
John Deere 6110M (A53317)
John Deere 6110M...
2021 Caterpillar 289D3 Compact Track Loader Skid Steer (A55973)
2021 Caterpillar...
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
2013 VOLVO VNL (A55745)
2013 VOLVO VNL...
2004 DCT PUMP TRAILER (A58214)
2004 DCT PUMP...
