HELP - Alternator/Generator Belt Removal/Installation - JD2040
   / HELP - Alternator/Generator Belt Removal/Installation - JD2040 #11
You may be on to something here. IF you don't mind me asking WHERE did you purchase this belt? What size and model/part number did you use. Thanks..
I get this stuff at the local woodworking supply shop up here, you buy it by the foot. I just used the old belt as a guide and got it on there, tightened it up, and back in business. You should be able to find it online easily if not locally, you want the the 1/2” size. Buy an extra foot, you don’t want to be a link short. It is pretty stiff when new.
Wanted to say THANKS to all that responded. I took the advice of "Eric M" and purchased a similar belt from Harbor Freight that was 1/2" x 5' and was $35.00. Removed several links and then installed. Seemed to fit just fine. Won't know in my case if it will work until I fire her up. Hopefully this will help others in the future.
   / HELP - Alternator/Generator Belt Removal/Installation - JD2040 #13
Good Luck, I am sure it will work fine. The stuff is more expensive than a regular belt but saves enough work to be worth it In situations like this.
2015 PETERBILT 367 HOT OIL (A50854)
2015 PETERBILT 367...
2011 Ford F-450 Crew Cab Omaha Service Truck (A50323)
2011 Ford F-450...
2019 Bobcat T770 Two Speed Compact Track Loader Skid Steer (A50322)
2019 Bobcat T770...
2025 Swict 78in Bucket Skid Steer Attachment (A50322)
2025 Swict 78in...
2022 Case TR340B Skidloader (RIDE AND DRIVE) (A50774)
2022 Case TR340B...
2015 Dodge 5500 4X4 Bucket Truck (A51039)
2015 Dodge 5500...
