HELP - Alternator/Generator Belt Removal/Installation - JD2040
   / HELP - Alternator/Generator Belt Removal/Installation - JD2040 #11
You may be on to something here. IF you don't mind me asking WHERE did you purchase this belt? What size and model/part number did you use. Thanks..
I get this stuff at the local woodworking supply shop up here, you buy it by the foot. I just used the old belt as a guide and got it on there, tightened it up, and back in business. You should be able to find it online easily if not locally, you want the the 1/2” size. Buy an extra foot, you don’t want to be a link short. It is pretty stiff when new.
Wanted to say THANKS to all that responded. I took the advice of "Eric M" and purchased a similar belt from Harbor Freight that was 1/2" x 5' and was $35.00. Removed several links and then installed. Seemed to fit just fine. Won't know in my case if it will work until I fire her up. Hopefully this will help others in the future.
   / HELP - Alternator/Generator Belt Removal/Installation - JD2040 #13
Good Luck, I am sure it will work fine. The stuff is more expensive than a regular belt but saves enough work to be worth it In situations like this.
2011 FREIGHTLINER M2 TANDEM AXLE FLATBED TRUCK (A51222)
2011 FREIGHTLINER...
2006 FORD F-750 WATER TRUCK (A50854)
2006 FORD F-750...
2014 VOLVO VHD DAYCAB (A50854)
2014 VOLVO VHD...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A51572)
IMPORTANT PLEASE...
2012 Ford Escape XLS SUV (A50324)
2012 Ford Escape...
TOP HAT TRAILER MFG. LIGHT PLANT TRAILER (A50854)
TOP HAT TRAILER...
