Help-950 3pt stuck
/ Help-950 3pt stuck #1
chriswheeler
Platinum Member
Nevada
John Deere 970TLB,
Hopeing that someone here has a way to unstick the 3 point hitch on a JD 950. Hitch is stuck in the up position. Hitch is not locked,
( Valve under the seat is open) but it acts like the piston is stuck in the bore??? I hung a disk on for weight and still nothing moves. The drop rate lever under the seat doesn't do anything, I have the lever pointed to the front, fastest drop rate. Any Help appreciated, thanks,
Chris
/ Help-950 3pt stuck #2
If you lift your seat and look underneath it, you should see a spring and a link hooked to it. See if the spring is broken or if the link is free to pivot on the control shaft. I am going to try and attach a photo of linkage. #4 is the spring and #2 is link that should pivot. If the link does not pivot, a little penetrating oil should help free it up. Don't use too much force or you could shear off te pivot point.
All is well that ends well I guess. The hyd shuttle valve above the 3 point cyl was stuck and after freeing it up all works as it should. Thanks for the direction, after seeing that the spring and linkage did what it should do I looked at the shuttle valve.
Chris
2013 Felling Trailers T/A Side Dump Flatbed Trailer (A56857)
2013 Felling...
2013 Atlas Copco XAS 400 JD7 Portable Air Compressor 125 PSI - Trailer Mounted - Tier 4 (A63689)
2013 Atlas Copco...
2013 John Deere Hydraulic Grapple Tractor Attachment (A61572)
2013 John Deere...
2018 Kenworth W900 Ext. Day Cab (A62613)
2018 Kenworth W900...
2023 New Holland C327 Compact Track Loader Skid Steer (A61572)
2023 New Holland...
3 Bottom International switch plow (A64119)
3 Bottom...
