Mowing Help!! 3PH/Underbelly mower hydro problems!
   / Help!! 3PH/Underbelly mower hydro problems! #1
MidgetMaestro
Ohio
Kubota BX2200, Farmall Cub
I recently sent my bx back (to the dealer for repair) after the implements I had mounted on the tractor kept drifting down once I stop pulling on the hydraulics lever. They sent it back saying they couldn't find any leaks, and they have no idea what's causing it to drop ... GREAT! just what i needed :eek:
Have any ideas??
I really need this fixed, cuz trying to grade with a blade that keeps drifting down is not fun :(
Thanks!
   / Help!! 3PH/Underbelly mower hydro problems! #2
The problem could be the stop adjustments on the hydraulic control lever rod. You will find the rod behind the right rear tire. It has two stops with two springs. You can reference kubotabooks.com bx2200d pages 155/156 . I had a similiar problem with the lever hitting the lift stop and dropping the implement.
thanks so much! I'll check it out!
CATERPILLAR 30 1/2" PIN ON BUCKET (A52706)
CATERPILLAR 30...
2008 New Holland B110 MFWD Loader Backhoe (A57024)
2008 New Holland...
2017 Ford F-650 Mason Dump Truck (A56858)
2017 Ford F-650...
TEST YOUR BID BUTTON! (A58375)
TEST YOUR BID...
2012 International Derrick Digger (A55973)
2012 International...
3410 (A47477)
3410 (A47477)
