Hello.....rant on horrible design.
/ Hello.....rant on horrible design. #1
LVKubota
Haven't checked in for a while....no news is usually good news.
Door handle on my 3710 cab model basically came apart. After removing and inspecting, I cannot believe it worked for any amount of time at all.
The handle bolts together sandwiching the glass door; the kicker is the nuts are round knurled and pressed into the plastic outside half.
Not only do they pull out, they crack/spread the plastic they're pressed into.
I re-assembled using expoxy to set the nuts in place......lasted a whole 1/2 dozen or so door openings/closings.
After reading here how anything with the Kubota name ,parts wise, is priced like it's gold, I fear what that half of the door handle will cost........oh wait, you probably won't be able to buy only half the assembly!!!
I also hate the fact that this assembly only lasted 200 hours....which I'm guessing is around 200 or less uses.
Thanks for letting me rant.....carry on.
/ Hello.....rant on horrible design. #2
Everyone always says that anything (insert name of brand here) is priced by it's weight in gold. I lost a flasher signal cover and was expecting it to be at least ten bucks but it was only a couple of dollars. You will spend more money than you should because you shouldn't be spending money on a door latch so soon but it might not be outrageous. Also check Tractorsmart.com
/ Hello.....rant on horrible design. #3
I used to use regular kneed epoxy for everything. Now I use PlasticWeld. It is still a form of epoxy, but on anything plastic does a fantastic job. After it sets up, it is there to stay.
Thanks for the site...........for whatever reason, they don't have the 3710C listed. I'll try calling 'em direct.
I may try it again....the way this is designed is EVERYTIME you open the door to the cab, the knurled/pressed in nut is trying to pull itself out....BIZARRE!!!
I'm thinking if I can find a new one, I'll reinforce it BEFORE installation.
New/Unused 72inch Quick Attach Rock Grapple Bucket (A65583)
New/Unused 72inch...
2022 EZ-GO ELITE...
STIHL FS80R POLE SAW (A64276)
STIHL FS80R POLE...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61567)
Pallet of...
1996 Sunflower 1543-38 Folding Disk (A63688)
1996 Sunflower...
2016 Land Rover Discovery Sport SUV (A61574)
2016 Land Rover...
