hello international 248 clutch problem
   / hello international 248 clutch problem #1
andrea felton
international 484 industrail
hi my husband is restoring a 248 industrial ih and weve hit problems with the clutch, fitted new plate bearings etc put it back together and still no clutch on pedal , took it apart replace thrust bearing sleeve and still no clutch, the pedal is still very low anybody got any ideas!!! you help would be much appreciated thanks andrea
   / hello international 248 clutch problem #2
Welcome to TBN. :)
thanks hope we can find some help : )
   / hello international 248 clutch problem #4
Hello & WELCOME to TBN!
I moved your thread to the Parts/Repairs Forum. :)
   / hello international 248 clutch problem #5
I forget if that model has hydraulics or a cable to control the clutch, if it is hydraulics, you will want to make sure it has enough fluid, then open the bleeder on the clutch, and pump the pedel, basicaly the same as bleeding brakes. I am guessing it has an airlock in the tube, and that is preventing it from fully activating. If it is a cable opperated clutch, check the tension on the cable.
1999 KENWORTH T800 DAY CAB (A53426)
1999 KENWORTH T800...
7096 (A51573)
7096 (A51573)
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
JOHN DEERE 7300 (A53084)
JOHN DEERE 7300...
JOHN DEERE 2032R LOT NUMBER 239 (A53084)
JOHN DEERE 2032R...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A53472)
Kubota 24in Quick...
