Hello From WV
/ Hello From WV #1
vegaome
New Martinsville, WV
1970 MF-135 and 1951 Ford 8N
Howdy Folks,
I live in the woods in WV and I'm looking to buy my first big tractor. Big to me is anything bigger than a garden tractor. I only have 57 acre farm but its pretty steep and mostly woods at the moment. I was thinking about getting a MF 135 or a Ford 3000. I enjoy reading the forums and all the help and advice people give. Thank you for your time.
v/r
Mike Daugherty
/ Hello From WV #3
Welcome to TBN. As you can see, I'm partial to the Massey 135.
/ Hello From WV #6
Welcome to the TBN forums from Missouri. :)
We have tried 2WD on our hill farms twice; sold one and moved one to our flat land farm; good luck.
/ Hello From WV
Thank you for the welcome everyone. Someday I would love to get a 4WD tractor. I do have to live within my means though. I see folks that get plenty done with smaller 2WD tractors and that's what I can afford right now.
But by all means don't let that deter you from voicing your opinion. The only big tractor I drove was an Oliver cleat tractor when I was a teenager. It did not even have a steering wheel. I have a big learning cure ahead but I have a couple neighbors who have tractors and can show me the ropes. Plus my fear of it rolling over on me. I will let everyone know what I end up with.
v/r
Mike Daugherty
/ Hello From WV #9
Hello Mike, welcome to TBN from Oklahoma. I'm partial to the MF, but the Ford is a good tractor too.
Ken
/ Hello From WV
Well Folks,
I put a 100 dollars down on a MF135 the other day. The right front hub is busted and the folks said the part should be in soon and they will put it on. Then I will go back and give her a good test drive and finish the deal. Its an older one. Gas tractor, 6 speed, bug head lights. The two stage clutch does work properly but not sure who much clutch is left. The three piont kind of works, the raise/lower lever is stuck in the up position so to lower you use the draft. Not sure what the hang up is there. I assume its the continental engine. The sheet metal is pretty beat up. It does have new tires all the way around. I forgot to mention, no muffler and the tach/hour meter does not work. All the other gauges seem to be working. I hope I can get some work out of her. Have a good day.
v/r
Mike
/ Hello From WV #11
A welcome to TBN. Have fun and enjoy hours of entertaining and educating reading. :welcome:
UNUSED IRGC40 HIGH-END ELECTRIC MINI GOLF CART (A62131)
UNUSED IRGC40...
1995 Crosley 20ft. 3 Ton T/A Equipment Trailer (A61568)
1995 Crosley 20ft...
2000 Mack CH613 Dump Truck (A59213)
2000 Mack CH613...
KBH 1600 Gallon Water Trailer (A64047)
KBH 1600 Gallon...
UNUSED WOLVERINE PFF2-13-45W QUICK ATTACH MAST (A62131)
UNUSED WOLVERINE...
APPROX. (15)-16' HDPE PIPE (A62131)
APPROX. (15)-16'...
