Hello from northern minnesota
   / Hello from northern minnesota #1
redneckdan
gilbert, mn
Farmall M
Long time lurker, first time poster.
Recently aquired a Farmall M in not too terrible shape. Reviving it for brush hogging and fire wood skidding around the house.
   / Hello from northern minnesota #2
Hi. Welcome. Glad you came in from the lurking. Good luck with your project.
We like pics.
Day I dragged it home. It does run now, need to install the electing ignition components I acquired for it.
Working on a three point hitch for it. I am about half way on the link bases.
Trying to decide if I should build a traditional lift linkage system or go with each side lifting independently. Down side would be having to fiddle with the leveling every time I lift the attachment. Upside would be the ability to re-level on the fly. For my uses, I don't this the down side would be that bad.
   / Hello from northern minnesota #4
Welcome to the forum!
That Farmall looks like a nice project.
   / Hello from northern minnesota #7
Welcome from Howell, Michigan. I have a Farmall H, with a Saginaw hitch, I think it is better than most OEM 3 point hitches. I have seen hitches made with adjustable side links. The downside is it is easy to break something... :) Do a search on here, there is plenty of info here.
Btw, nice WFE, looks to be a original IH. I've heard that they have a pretty wide turn radius?
   / Hello from northern minnesota #8
My grandfather graduated from HS in Gilbert in 1918? Last is name is LaLonde.
   / Hello from northern minnesota #9
Hello from Idaho! I love vintage tractors and yours too. It will be interesting to watch your progress on your hitch build. Thank you for sharing. I am new to this site as well. I find it helpful and welcoming.
2025 K1912 UNUSED Metal Livestock Shed (A53117)
2025 K1912 UNUSED...
2018 Kubota M5-111 (A50123)
2018 Kubota M5-111...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
2018 Ford F-250 4x4 Crew Cab Gooseneck Flatbed Truck (A51691)
2018 Ford F-250...
Halla LF30C 6,500lb LP Forklift (A51691)
Halla LF30C...
2003 Paris Utility Trailer (A52377)
2003 Paris Utility...
