Hello from northern minnesota
   / Hello from northern minnesota #1
redneckdan
gilbert, mn
Farmall M
Long time lurker, first time poster.
Recently aquired a Farmall M in not too terrible shape. Reviving it for brush hogging and fire wood skidding around the house.
   / Hello from northern minnesota #2
Hi. Welcome. Glad you came in from the lurking. Good luck with your project.
We like pics.
Day I dragged it home. It does run now, need to install the electing ignition components I acquired for it.
Working on a three point hitch for it. I am about half way on the link bases.
Trying to decide if I should build a traditional lift linkage system or go with each side lifting independently. Down side would be having to fiddle with the leveling every time I lift the attachment. Upside would be the ability to re-level on the fly. For my uses, I don't this the down side would be that bad.
   / Hello from northern minnesota #4
Welcome to the forum!
That Farmall looks like a nice project.
   / Hello from northern minnesota #7
Welcome from Howell, Michigan. I have a Farmall H, with a Saginaw hitch, I think it is better than most OEM 3 point hitches. I have seen hitches made with adjustable side links. The downside is it is easy to break something... :) Do a search on here, there is plenty of info here.
Btw, nice WFE, looks to be a original IH. I've heard that they have a pretty wide turn radius?
   / Hello from northern minnesota #8
My grandfather graduated from HS in Gilbert in 1918? Last is name is LaLonde.
   / Hello from northern minnesota #9
Hello from Idaho! I love vintage tractors and yours too. It will be interesting to watch your progress on your hitch build. Thank you for sharing. I am new to this site as well. I find it helpful and welcoming.
2025 CFG Industrial MX12R (A50123)
2025 CFG...
2012 KENWORTH T 7 DOUBLE BUNK SLEEPER (A53426)
2012 KENWORTH T 7...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
2006 Acura RL Sedan (A51694)
2006 Acura RL...
Single Axle Rear Truck Frame (A51692)
Single Axle Rear...
2004 Ferrara Pumper Fire Truck (A51692)
2004 Ferrara...
