Hello from Hampden, Massachusetts
   / Hello from Hampden, Massachusetts #1
K Arno
Hampden, MA
John Deere 2032R
Got a new 2032R about 10 machine hours ago that got delivered with backhoe and front end loader attached and a snowblower and the forward power gear with a weight box and three point hitch placed in the garage. Foolishly passed on ground school at delivery and went out and started agitating gravel. A retired 88Z don't need no stinking instruction. Popped a bunch of rocks, filled potholes in the driveway with a ten wheeler load of reprocessed concrete, popped a big maple stump. We are cooking with gas now. Dropped the FEL and Hoe and started hooking up the three point hitch attaching the ballast box and the front mount snow blower and all the hook up parts.
The snowblower lines from the unit itself are color coded yellow and silver. The lift attachment hoses are black and green. The tractor has ports coded yellow black red and blue. Match the colors that did and took a guess at the remaining two. No joy. Swapped the non matching pair still no joy.
Can someone here tell me the ports on my tractor by color for lift/drop and or right left or curl on the SCV. Thanks in advance and thanks for taking me on Bord.
   / Hello from Hampden, Massachusetts #2
:welcome:aboard, I can't help you with that. Maybe someone else might chime in.
   / Hello from Hampden, Massachusetts #3
Hi. Welcome. I am sure several on here have the same model and can help.
   / Hello from Hampden, Massachusetts #4
Welcome to the forum!
:tractor: I'm going to move your thread over to the JD section. Someone over there must know.
Thanks Catherine TBN
I would love to have this working before the dealer opens back up Monday. No snow in the forecast so no panic...
Thanks also for the welcomes, I am glad my brother pointed this site out to me. Thanks all.
   / Hello from Hampden, Massachusetts #7
In the operators manual the color coded dust caps are identified. Look under 'using hydraulic control levers' this identifies the pairs of valve couplers and direction of flow with their position and color.
I have the manual open to page 05-25/26. Page 06-25 lists the 2025 color code, they don't match the 2032. Go figure. on a cold start today the implement lifted. Thought hey maybe just some air... shortly later the party was over. Over pressure relief valve shutting me down?
How do I relate the decal with the ports? page 06-26
I can't find any numbers near the ports, just yellow red blue and black plugs....
   / Hello from Hampden, Massachusetts #9
Try the top two couplers as a pair for raise/lower and the bottom two couplers for curl.
   / Hello from Hampden, Massachusetts #10
Black and green should be one pair, yellow and silver should be the second pair.
On my mower the upper set is black and green the lower set is yellow and silver looking from left to right facing the couplers.
Light Tower (A52377)
(INOP) 2005 BRODERSON IC80-3G 9 TON ROUGH TERRAIN CRANE (A51406)
(INOP) 2005...
UNUSED Double Stall Portable Bathroom (A53117)
UNUSED Double...
2006 Davidson Pro 534-20 20' Ladder (A53117)
2006 Davidson Pro...
2014 CATERPILLAR 305E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
