Hello from Hampden, Massachusetts
   / Hello from Hampden, Massachusetts
Just took an other look.
On the tractor the top two ports are from left to right Black (1)? and Yellow (2)?. snowblower Lift and Drop?
just below and offset to the left are Red (3)? and Blue (4)?. discharge chute left and right aka curl?
The lines coming from the blower are Yellow and silver I believe they should connect to the curl
(left and right) on the control stick (3) & (4)
The lines coming from the front lift are Black and Green I believe they should connect to lift down/float
back and forward on the stick (1) & (2)
North is dead ahead from where I am sitting. Past that things are a bit murky.
Love it when a plan comes together. The top ports on my machine do the curl. The bottom two do the lift. Will get the right color caps when the dealer opens back up Monday but all the toys are working as they should. Thanks to all that pointed me down the right path.
Stopped at the dealer today. They gave me the right color caps and all is well.
LOT: (4) Large Wheel Chocks (A59076)
LOT: (4) Large...
2022 Ford Escape S AWD SUV (A54815)
2022 Ford Escape S...
2017 Rogator RG1300B Dry Fertilizer Applicator (A56435)
2017 Rogator...
(3) DRILLS (A58374)
(3) DRILLS (A58374)
HYD AUGER W/ 10" BIT (A52708)
HYD AUGER W/ 10"...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
