Height Measurement B3030?
/ Height Measurement B3030? #1
wkasak
Elkridge, Maryland
Can someone please give me a height measurement for a B3030 to the top of the ROPS? I am planning a storage building and want to make sure there is enough garage door height to clear the ROPS without having to put them down.
Thanks in Advanced...
/ Height Measurement B3030? #2
Kubota site says 80.4 inches, transport height
here
That measurement is for the backhoe transport height. Maybe the backhoe would be the highest part to clear the opening? Or are the ROPS higher? It will have a backhoe.
/ Height Measurement B3030? #4
The ROPS bar is usually higher when you have a backhoe, I suggest you use the backhoe ROPS height for your door.
Ok...so does anyone have a B3030 w/backhoe ROPS and a tape measure to verify the height? Is 80"-81" correct?
/ Height Measurement B3030? #6
i have a B3030, with BH. My garage door is 7' = 84". I just fit, comfortably. With a 3030, you must order the folding rops with the BH. A 7' door is minimum. Does this answer your question?
/ Height Measurement B3030? #7
I stand corrected - my garage door in my shop is 8' and I clear by a couple of inches with my foldable ROPS up. I can not fit into a standard 7' door without puting the ROPS down.
/ Height Measurement B3030? #8
Here's my measurements for my B3030 (w/ Kubota BH and FEL):
ROPs Height: 88"
BH height: 79" (full raised position)
Overall length w/BH and FEL attached: 210" (BH full raised; FEL down)
Width of B3030 w/rear wheel spacers: 58"
When I built my garage I had a 10' door installed for my conversion van. I don't even think about my ROPs when I put the B3030 to bed. (Hope I never decide to put it in the other garage 'cause I bet I'll be replacing a garage door frame.)
Thanks to All...I have plans for 8'/96" high garage doors so it appears I will be ok.
/ Height Measurement B3030? #10
Your good to go.
