Traction Heavy Tractor vs Light in Soft Sand
   / Heavy Tractor vs Light in Soft Sand #11
ElDumpoGrande: glad info was helpful. As for traction in sand, I believe you still want flotation; trying for traction with aggressive tread means digging in deeper, quicker. And, "industrial" tires, designed to support loader operations, generally have stiff sidewalls so that airing down doesn't give you as much flotation.
Lots of info in the 4-wheeling community about "dune-ing". Whatever you choose, if sand is your predominant surface, I definitely wouldn't load the tires so that "airing down" is practical when called for ...and, maybe an on-board compressor for airing back up (although the volume of tractor tires is so large that airing up would really take some doing.)
Hope everything works out.
   / Heavy Tractor vs Light in Soft Sand #12
heavy tractor with radials.
   / Heavy Tractor vs Light in Soft Sand #13
Actually cupped 'paddle' type tires that are sometimes used in rice fields will provide the best traction in soft sand. If there were any better tires for sand, they would use them on these machines. ‪CANIDAE Sand Drag‬‏ - YouTube
   / Heavy Tractor vs Light in Soft Sand #14
agree with radials, as radial construction allows greater sidewall flex as compared to bias-ply tires.
And, yes, cupped tires as described aim to combine flotation and traction.
   / Heavy Tractor vs Light in Soft Sand #15
I was about to suggest rice paddie tires, they were "standard" at one time on some Asian and Chinese imports - they may still be an available option.
I am fairly sure that I have seen tires similar to what are on that Youtube video on a JD small Cat 1 tractor recently.
I will be at that farm tomorrow and will try to remember to check it out.
Less "aggressive", but a similar pattern.
Yes to the other comments that pressure is pressure (-:
GENERALLY standard R1s offered will be narrower and have a higher ground pressure than the optional R4s or R3 turfs - - from many/most tractor manufacturers.
DRY sand probably won't clog turfs, wet "clay sand" probably will, wet "sandy loam" can, but how wet will you work the ground ?
Sandy loam drains SO quickly around here anyway that I barely have time to start the tractor up and attach an implement before it is "dry" (-:
I've mentioned it before, there are exceptions to this - for manufacturers standard size optional tire/wheel combinations the R4s will not only be wider with a lower ground pressure than R1s, they will also have a larger fluid capacity.
So IF you need ballast and decide you need it in the tires the R4s will GENERALLY get you more of it.
Again, rutting is usually more a function of taking sharp turns on wet soil than the actual tread pattern - also of driving with the tractor wheels in EXACTLY the same "slot" all the time. Just nudge over a couple of feet on return runs, if you see ruts developing drive ON the RIDGES (-:
Reg/Dargo/JoeL4330/cowski:
Even though the Mahindra dealership I've been talking with is good, I've definitely learned more about tires on this site than I ever could from them. Thanks to you and everyone else who responded previously. -I've inquired about radials, and that's a no go, at least thru Mahindra. Interesting about the rice paddie tires, but that's a no go, too. Since I'm looking to buy new (and a Mahindra) I've only got the options to use their R1, R3, or R4 standard poly tires, so I'll be going with the latter. Reg, like you were saying about your sandy soil, mine also drains off very fast after an inch of rain, for example, but when there is a long saturating rain, the water finds a shelf of impervious clay about 2 feet down, and it sits there, leaving the sandy soil mushy. (Not that it rains like that in Texas anymore.) Of course, no matter what type of tires I've got under those circumstances, the tractor will probably just be sitting in the barn. Someone asked about how I'll be using the tractor. Mainly, using discs or tines, digging post holes, and, of course, shredding. I also have a lot of grapple work to do, moving big tree limbs and brush.
   / Heavy Tractor vs Light in Soft Sand #17
Eldump, how did the R4's work out? I have a farm in East Texas and we have real fine sand, some people call it sugar sand. My Ford 1700 has Ag tires and it does tend to dig in if it gets in a bind. It is 4WD so that dont happen often but it dosent have a FEL. Sometime when using my box blade to move dirt it has to much weight and digs in so I have to raise the box blade and let some dirt out.
I am looking to purchase another tractor in the next month with a FEL so I am researching the best tire tread design. Thats how I came across your thread.
   / Heavy Tractor vs Light in Soft Sand #18
I have sand here as well ... one tractor has R4's and one has R1's ... I seriously have a preference for field work ... the R1's seem to be better ...If the wife wants something moved in the yard then I come in with the R4's
DaHo,
Athens, huh? Been there a number of times when in the Tyler area. At any rate, R4s have been good, especially when making the first or second pass with discs. A little spinning involved, however, if making third run with the discs as the sand gets loser. All in all, happy though. Think maybe my sandy soil isn't as lose as some of the others who replied. Flotation seems ample enough with the R4s.
2022 RAM 2500 HEAVY DUTY (A55745)
2022 RAM 2500...
2018 Freightliner Bucket Truck (A55973)
2018 Freightliner...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
2012 MACK GU713 (A58214)
2012 MACK GU713...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A55315)
Michelin CARGOXBIB...
Caterpillar D5G LGP (A53317)
Caterpillar D5G...
