Heavy Hitch
   / Heavy Hitch #11
that limiter chain is a good idea, as long as you don't forget and actuate the 3pt lift. I bet you some tractors could bend the draw bar or atleast rip the hook off.
   / Heavy Hitch #12
I have my chain set so the max lift is just starting to pull on the drawbar.
   / Heavy Hitch
If you are going to use that for moving trailers around I'd recommend a safety chain so that the 3 point can't be pushed up higher then it should go.
You can see my limiting chain going down to a clevis in the drawbar to stop unintended over lifting.
Definitely going to do this!
   / Heavy Hitch #14
I made one using my old 3PH drawbar. The hitch isn't rocket science, if the vendor product is cheaper/faster than you can make it then buy it.
MODEL 14C SCRAPER (A58216)
MODEL 14C SCRAPER...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
UNUSED FUTURE FT-180H HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
1643 (A58375)
1643 (A58375)
Heavy Duty Excavator Ripper (New/Unused) To Fit CAT320 (A59225)
Heavy Duty...
2015 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2015 UTILITY VS2RA...
