Heavy duty antifreeze?
/ Heavy duty antifreeze? #1
ToJo
AL
Kubota L3400 FEL
I have read that diesel engines need heavy duty antifreeze. I prefer propylene glycol to ethylene glycol. Anyone know a good brand of heavy duty propylene glycol?
/ Heavy duty antifreeze? #2
Evans coolant is a non-aqueous propylene glycol. You don't use any water or a pressure cap. Or Amsoil has some.
/ Heavy duty antifreeze? #3
Depending on the engine, some don't react to well to low silicate extended life antifreezes. You could experience water pump shaft seal leaks.
/ Heavy duty antifreeze? #4
I can't imagine why, unless the cooling system were undersized/improperly designed to begin with. Cubic-inch-for-cubic-inch, Diez-els are on average 30% more efficient than their gasoline cousins; that means proportionately less energy is wasted as heat. Which is why it takes Diez-els so dang long to heat up in cold weather, and why some vehicles even have auxiliary heating elements in the heater core loop to get the core (and the wifey's little toesies) warmed up even faster.
What defines "heavy-duty antifreeze"? Your cooling capacity can be extended by simply using a higher coolant-to-water ratio. On my Kubota I've never seen the needle past 1/4 of the gauge, even in 95 degree heat and mowing at about 10mph, using the "stock mix".
/ Heavy duty antifreeze? #5
Low-silicate with SCAs or DCAs (supplemental or diesel coolant additive) which is a nitrite which helps to prevent cavitation of wet-sleeve diesel engines or thin-walled diesel engines like the International 7.3L. Fleetguard is a good example of a diesel-rated coolant (made by Cummins).
/ Heavy duty antifreeze? #7
I dont want to seem to disagree because this is effective as you say. I seem to remember tho that water is the superior heat mover at a given T. The problem at higher T is that higher pressure is needed to keep water a liquid. Due the need for anti corrosion and freeze prevention water is going to be modified anyway with the anti freeze additive, incidentally providing anti boil as well. So our systems are not designed for the higher pressure needed by pure water. The quibble point is that in extending the anti boil up by additive, you get a coolant that is [slightly] inferior to water, but beats it because it can be used at a higher temperature at the designed system pressure.
Thats the way it fits together for me.
larry
/ Heavy duty antifreeze? #8
OK I learned a couple of things. Now, since I've never owned a diesel that had sleeves or thin walls (including this Kubota), I guess I never had a need-to-know about this other issue.
Maybe we oughtta back up a second and ask - do any of these Kubota engines fit the definition of the problem that requires the treatment with supplemental additives? If the answer is No, then we can treat this entire discussion as N/A.
/ Heavy duty antifreeze? #9
i think all engines need anti freeze and corrosion. Most will need anti boil as well. They all pretty much come as a result of one another. Then theres the cavitation thing on some diesel cylinders that I think youre refering to. Is there an additive for that? How does it work?
larry
2026 SDlanch SDLE20 (A64127)
2026 SDlanch...
213101 (A64276)
213101 (A64276)
2019 ISUZU NPR 4X2 S/A 18FT FLATBED (A59912)
2019 ISUZU NPR 4X2...
2021 KOBOTA SVL97-2 SKID STEER (A65053)
2021 KOBOTA...
New Electric Scooter (A65579)
New Electric...
3pt Heavy Duty Carry-All, 3'x6' Platform (A62679)
3pt Heavy Duty...
