HEAVY DUITY BOX BLADE
/ HEAVY DUITY BOX BLADE #21
Brad,
<font color=blue>$2400 for a TB372 (6' model w/ hydraulic scarifiers, just over 1000lbs). It was quite a bit more than I expected.</font color=blue>
What are your thoughts on the hydraulic box blade you just purchased vis-a-vis a non-hydraulic one in combo with a top and tilt kit? I want to get a box blade in the future. I know the hydraulic ones are very expensive just like what you've cited. Good non-hydraulic ones can be purchased for half the price or less. Top and tilt kits are around $600-700 plus install. I figure going this route will save me $500-600 or more. What are your thoughts....particularly interested in operational efficiencies or advantages of the hydraulic boxes versus non-hydraulic ones? Thanks.
Regards,
Bob Ancar
Cambridge, NY
The hyd. ripppers are worth their money in platinum.Ihave a feeling Ill be purchasing hyd. top&tilt fairly soon it just makes life a lot easier no getting off the tractor screwing top or tilt links for 2 passes then doing the same thing again to get it back level
/ HEAVY DUITY BOX BLADE #23
Rancar,
I didn't buy that Tufline box blade. Seemed too expensive to me. That was the 372 model for $2400, the 272 was only $800. Seemed like an awfully big jump for just a little more weight and the hydraulic scarifiers.
I do have TNT and I have a 3rd SCV on the back, hopefully to use hydraulic scarifiers and possibly a hydraulic angling blade. Maybe I can find a Cammond dealer close by. $1600 is getting a little in more in line with what I was expecting.
If I ever find one and find the money at the same time, I'll let you know how it works out.
--Brad
2009 ALLMAND  MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2009 ALLMAND...
2014 HIPOWER 310 Generator (A67714)
2014 HIPOWER 310...
More info coming soon. (A64557)
More info coming...
2006 FRAC TANK 500BBL WHEELED (A68842)
2006 FRAC TANK...
2003 TEREX  60 TON CRANE (INOPERABLE) (A67714)
2003 TEREX 60 TON...
2016 PETERBILT 337 CAB AND CHASSIS (A65643)
2016 PETERBILT 337...
