Snow heavy blower
/ heavy blower #1
glsmith05
Barrie Ontario canada
265 john deere
Hello group, i just got a JOHN DEERE 265 with a blower attachment and found the blower very heavy so i purchased a lift kit and installed it and it helped allot but even before i put the kit on i found that i had to press downward with a fair amount of force to latch it into the locked down position.
is there an adjustment to reduce the pressure required to latch it down ?
/ heavy blower #2
:welcome:
You have to overcome the spring that is built in to help lift the mower deck...if I am hearing you correctly.
Do you need to latch it down, or can you let it float?
/ heavy blower
I do understand what you mean by the lift spring . no i don`t think it would work well floating it would bounce all over.because its almost neutral weight now since i put the lift kit on.
i don`t see how i can get arround it , i guess its not that bad.
thanks for the response.
/ heavy blower #4
Don't see any adjustment to make it less of a push to lock it down.
Heres hoping that you can make the move to hydraulic assist on your next trade. You deserve it. :)
2012 Ram 1500 Crew Cab Pickup Truck (A61573)
2012 Ram 1500 Crew...
2011 Chevrolet Express 2500 Cargo Van (A61573)
2011 Chevrolet...
EZ-GO GAS GOLF CART (A63276)
EZ-GO GAS GOLF...
2003 Ford F-350 Flatbed Sprayer Truck (A61573)
2003 Ford F-350...
2021 Walker Neuson G25 Quiet Power 20kW Towable Generator (A61572)
2021 Walker Neuson...
2019 KUBOTA KX033-4 EXCAVATOR (A60429)
2019 KUBOTA...
