Grapple heavier grapple or not
   / heavier grapple or not #81
I agree that someone doing commercial quantities of firewood would be best off with a wide grapple. Cleaning up construction sites is another example where wider is indeed better. However, there are convenient work arounds that require pretty simple changes in process to accommodate a narrow grapple. For example, instead of cutting logs into 16" lengths and then loading them into a grapple for transport to the splitter, how about cutting logs to eight foot lengths and transporting them that way for finer cutting right at the splitter? I'd imagine you could carry even more in one load that way than you could with a wide grapple holding 16" lengths as overhang is no issue so long as you could drive out of the woods.
Still, I do see your point. Most of us are not using grapples for commercial firewood quantities or construction but rather cleaning up land and doing a variety of grappling tasks. The bottom line is that any grapple is better than no grapple and that to my knowledge no one on TBN with a wide grapple has traded down and no one with a narrow light duty grapple has traded up. Everyone loves their grapple. You cannot say that for tractors or other implements by and large.:)
The new tractor has made it home but... i have yet to pull the trigger on a grapple. In my prior post... weight and lift capacity were slightly off...okay a lot off.
Lift capacity at max height 2469 lbs
Lift capacity at 5 feet 3210 lbs
weight of tractor with FEL 6681 lbs
Are there any disadvantages with a 48" grapple on larger tractors as for as being able to see the grapple?
   / heavier grapple or not #83
The grapple size is not the issue here but rather the distance and height from the grapple tines from the operator station. I could see better with my smaller Kioti CK20 than I can with my DK40se but it is due to the size of the engine hood not the grapple.
   / heavier grapple or not #84
Nice tractor. What happened to your loader handle??
It's just a Kubota engineering Oops...The bend in the loader handle gives clearence for the gear slector handle. However, the new location of the loader joystick is much better than the old placement...which makes the operater reach forward for the joystick.
   / heavier grapple or not #86
The visibility of the grapple tines from the operators seat are somewhat of a challenge when operating my tractor. I can see the outer tines fairly well on either side of the hood and will get along ok for most work so far. But....I constantly have to shift from one side of my tractor hood to the other to get a look at whats happening out front.
But, seeing at the center (of a bucket or grapple) requires standing up...which shuts down my tractor (and requires me to remove my seatbelt). :mad: It's worse with a bucket for me as you cannot see through it...as you can with the grapple.
Something I wish for is a button to temporarily over-ride the seat shut-off switch....while I stand-up to have a look. And....maybe another button to replace my seatbelt? ;)
In years to come we will all have camera's and screens to let us have a better look. :thumbsup:
I temporarily disabled the seat shut-off switch on my L3130 with a wide zip tie. It will hold the switch in the down position.
   / heavier grapple or not #88
I'm gonna take my grapple off and put the bucket back on today. First thing I'm going to do after that is try to get a feel of the lifting capeability difference.
   / heavier grapple or not #89
Nothing like a good grapple discussion!
Of course the best solution is buy a 48", 72", and Stump Grapple! If one grapple is good three must be fantastic!!
:laughing:
   / heavier grapple or not #90
:laughing:
The 'extend-a-grapple'! Now I know I'm gonna get rich! Accordian attachments.com!
2014 Ford Explorer AWD SUV (A55853)
2014 Ford Explorer...
2016 Freightliner M2 106 4x4 Altec Bucket Truck (A55852)
2016 Freightliner...
2007 Kenworth Tandem Axle Road Tractor (A47477)
2007 Kenworth...
John Deere Miniature Decorative Truck (A55853)
John Deere...
1998 HONDA 300 FOURTRAX (A57192)
1998 HONDA 300...
UNUSED FUTURE SZYMJ HYD STUMP GRINDER (A57193)
UNUSED FUTURE...
