heater
/ heater #1
Anonymous Poster
Epic Contributor
has anyone thought of away to provide heat to the operater in cold weather? I don't have a cab and don't want one , how ever alittle heat on the cold mornings would be nice.
/ heater #2
i have often given it a thought and my idea was to get a heater coil out of a old car and tie it into the colling system and put a fan behind it to blow in the war air
/ heater #5
I bought a heater from Curtis Cabs. it is basically a heater core with a fan behind it. It is a nice little unit, that comes with 5/8 heater hose that hooks into a T adapter that they provide. The adapter goes into the bottom return hose that attaches to the radiator and the feed line is a 5/8 fitting that goes under the thermostat housing. They provide the threaded fitting and on the B2710 there is a Threaded Bung Plug that you remove and replace with the fitting. A wire runs to any 12V source in the fuse box and they include a 2 position (HI/LO) switch. At $249 I thought it was pretty reasonable, it would cost at least that to put one together yourself........
/ heater #6
Maybe some canvas run back from the rad to direct the fan air back to the operator would work. Used to call them heat houser's before the days of cabs. The canvas goes on the outside and covers the sides of the engine.
Egon
/ heater #7
Jason:
Can you post any pictures of your installation?
Kip
2003 CASE 70XT SKID STEER (A64279)
2003 CASE 70XT...
2007 MACK GRANITE CTP713B DUMP TRUCK (A64280)
2007 MACK GRANITE...
2013 Toro Groundsmaster 3280D 72in. Commercial Riding Mower (A64194)
2013 Toro...
2020 INTERNATIONAL LT625 SLEEPER (A59910)
2020 INTERNATIONAL...
2018 HARPER ATM 72LC MOWER (A66091)
2018 HARPER ATM...
2025 SDLANCH Rachet Tie-Down Strap (A64194)
2025 SDLANCH...
