Heater issues
/ Heater issues #1
250quality
Ontario
Kioti DK55
Winter's coming and little heat in the cab! Anyone else have a DK55 that has poor heat output on a cold day? The dealer told me that they were known for this and just wondered if anyone had a solution other than a trade in.
I don't freeze by any means but still gotta wear a coat when plowing snow.
/ Heater issues #2
My 45 has the same issue.I bought a plug in 12v electric heater. Placed it behind the seat. It keeps the rear window clear plus adds a little extra heat. Also, I switch the air circulation to cab air recycling - this helps too.
Good luck.
/ Heater issues
Yea but where you are in the winter a woodstove in your 45 would be pushin it to keep warm.
Thanks and i'll try the electric addition this winter.
/ Heater issues #4
Might a thermostat change be in order?
I recall when cars had winter and summer stats. and when some folks restricted the rad airflow with cardboard sheet with a hole cut out in the center.
/ Heater issues #5
My dk45 roasts me out of the cab... i cant put it over 1/2 way or it gets too hot.
It just migh be a thermostat issue.
/ Heater issues #6
I had a window fogging issue on my DK45SEC, to cure the problem i went with an aftermarket thermostate, since kioti has only one model which is a 180. Now i must remove my coat and put down the heat to stay in the cab, even in the freezing winter days of Quebec.
/ Heater issues
Yea I hear the new ones are way better. Maybe a trade in will fix the problem.
/ Heater issues #8
I do not know if this is is from a change Daedong made or just Bobcat, but Bobcat's parts list shows a different part number for thermostat on tractor with cab vs open ROPS machine. I can find no specifications that list the different temps on the thermostat, only one in the manual is 185 F. Anyway the Part Number from Bobcat is 7010319 and Daedong/Kiotoi P/N is E5853-73011.
Check the heater valve in top of the cab to make sure it is going to full open, if OK then look at thermostat.
/ Heater issues #9
My kioti parts book only lists 1 thermostat and doesnt show a difference between open station and cab. they list part # E5800-73011
hmmm, you would think a cab with heat would be different, wouldnt you?
/ Heater issues #10
That part number you have is the one that Bobcat number crosses to for the open station. I think this thermostat change occured a year or so after the cab came out for the new DKs & Bobcat tractors, you may have an older parts manual. Check with your dealer and see if they list the other one. If not call aa bobcat dealer and give them the part number I listed before.
/ Heater issues #12
Regardless of part numbers and open station or not; if one takes a t-stat and drops it in 185+ degree water you will see if the stat in use is opening all the way or just partially. If partially then it is not working properly. Replace with an OEM or aftermarket to the same rating as original.
/ Heater issues
Gotta be stuck open cause I can't even get it up to operating temp anymore.
You would think that that big ol 8 foot snow pusher and the 3-4 inches of snow we got last night would warn it up. Service guy is coming to my shop tomorrow so gonna have heat and defrosted windows soon!!
/ Heater issues
New T-stat in today with great results. Never seen the temp gauge up to where it is now. Seems it had the wrong one in it from the get go.
In think it said 74 degrees on the existing one.
/ Heater issues #15
yeiks... well glad its all working out
/ Heater issues #16
You should see lower fuel consumption too now. Diesels don't like to run cold.
3PT SPRAYER RACK (A64278)
3PT SPRAYER RACK...
VANTAGE 38' FRAMELESS ALUM DUMP TRAILER (A64278)
VANTAGE 38'...
1984 Charles Machine Works S4A S/A Tilt Deck Trailer (A61573)
1984 Charles...
213324 (A64279)
213324 (A64279)
2021 CATERPILLAR D4 LGP CRAWLER DOZER (A65053)
2021 CATERPILLAR...
2011 Kenworth T400 33Yd. Side Loader Garbage Truck (A64194)
2011 Kenworth T400...
