heat pumps
/ heat pumps #21
mjarrels said:
We have friends who live next to a cave and that is where they installed the outside unit... constant 50 degrees inside the cave.
mark
It's not those GEICO guys is it. :)
/ heat pumps #22
shaley said:
The larger the duct system the more dead air it holds. When a system gets larger than 3 tons this becomes a factor. I like to see two units (split zones) at that point vs. one big 5 ton unit.
"All things equal", it makes more sense to zone a system rather than putting more than one system in if you can still meet the load requirements with one system (cost wise). For my house, I have three systems, not the way I would of designed it, but that's what I'm stuck with and it would be a royal bi*&ch to change it, if not near impossible.
Most houses are not built for HVAC sytems, the HVAC systems have to be built around the houses. Wait until some of you have to replace a system with a new 13 SEER system or higher. The coils are bigger and some of you may be in for a surprise as far as to how much space you actually have to work with.
And from what I've seen, people won't bat an eye to upgrade 5k to 10k in kitchen cabnets or bathroom/sink fixtures, but god, have to upgrade the HVAC system by 1k and they have a heart attack.
/ heat pumps #23
My 1999 Rheem heat pump says "High Efficiency" on the top, but I've not found anything to tell me what the tonnage or the seer is. I'm sure that's only because I don't know what to look for.:eek:
/ heat pumps #24
What fails first on heat pump systems, inside air handler or outside unit? Mine are about eight years old.
mark
/ heat pumps #25
Bird, look at the model number. Some nomenclatures are hard to read, but some may have a 18,24,30,36,42,60 in the model number wich tells you the tonnage. Sorry to say, "High Efficiency" means nothing when it's written down on the equipment. Usually you will find a rating plate on the outside unit (as well with any HVAC equipment) that should at least give you the basic information.
/ heat pumps #26
You mean as in the attached photo? That's the plate that's on the outside unit.
/ heat pumps #27
just my $0.02, I have a 3200 sq ft (living) home with two heat pumps. I would never go the heat pump route again. Too drafty..............
/ heat pumps #28
I guess, as with lots of things, it's primarily a matter of personal preference. One of my wife's brothers used to live in a house with one and liked. Another of her brothers has one now and likes it. My cousin used to have one and didn't like it. And now we have one and are happy with it so far.:) Drafty? Yeah, a little bit, but not enough to bother me. I hope its more energy efficient than what we've been accustomed to, and since it's 7.5 years old, I'm hoping it lasts a long time.
/ heat pumps #29
mechanic,
I didn't see any mention regarding water or ground source heat pumps which are much more efficient than air source heat pumps since they derive their heat from the earth or water supply which is at a steady state ~50 year round. These systems can even provide all your hot water needs in summer(cooling mode) via a desuperheater and even have options for heating your pool. Check out some of the below links as well as an article regarding the most recent DX version - Enjoy!!
Geothermal Resources Council
Geothermal Heat Pump Consortium, Inc.
ClimateMaster Inc. - Welcome to ClimateMaster.com
What is geothermal? | Frequently Asked Questions
GeoComfort.com
  • Gound-Source = Heating and Cooling Gets Better.pdf
/ heat pumps #30
Bird, your outdoor unit is a two and half ton thirteen SEER heat pump. Keep in mind, depending on what it's "matched up" per the indoor coil/blower/air handler, ratings may differ per the manufacturer (one example would be if an expansion valve was installed or not).
Surprised that for the time (it was made on the 24th week in 1999) that someone did actually put in and spend the extra money for a 13 SEER unit.
/ heat pumps #31
techman said:
Last but not least, do not use a night setback thermostat. The warm-up in the morning will force the heat strips to come on and it will kill the efficiency of the system. Over 30% more power is used overall when a set back is used. Set it and forget it, and it will operate most efficiently.
paul
I purchased a digital thermostat at Home Depot a little over a year ago that is designed for a heat pump. It states that the auxiliary heat won't be activated unless the bump-up temperature is really different. Five or six degrees never activates the auxiliary heat. It should actually be much more efficient than my old manual version, since aux heat would come on pretty easily on it.
So, I think it's working the way I say it is. I've only managed to active aux heat by manually bumping the temp from 62 to over 70 degrees. Downside is that it does take a long time to raise the house temp a few degrees.
/ heat pumps #32
Su7 said:
mechanic,
I converted to geo heat pumps a couple of years ago (see: http://www.tractorbynet.com/forums/rural-living/74680-geothermal-heat-pump-project.html ). The ground temp does vary seasonally, mostly due to the heat/cool you are dumping in to it, but still a great improvement over air systems.
I agree it is a great system. My only other comments are regarding DX systems. They look great on paper, but I have seen quite a few problems with DX units. Most soil has a thermal transfer rate of about 1 btu/hr/deg F. You can't get much of an efficiency improvement when the soil is the biggest thermal issue. You will see good efficiencies at first, but the soil will cool down (or heat up) over the season and lower efficiency as time goes on. The thermal transfer of the plastic tubing used in regular ground source heat pumps is 10 times better than the soil. Additionally there can be issues with corrosive soils that can lead to very expensive repairs if the copper tubing corrodes.
There were quite a few DX manufacturers in the early days of geo heat pumps. Most are gone today, with just a couple left. That says something.
paul
/ heat pumps #33
fishman said:
I purchased a digital thermostat at Home Depot a little over a year ago ...
You did the right thing. Very few programmable thermostats have that capability, and most people buy one off the shelf and end up paying big time for the supposed "cost savings" of using night setback.
Buyer beware
Paul
/ heat pumps #34
Hmm, I remember hearing something about an expansion valve, but don't remember what it was.:rolleyes: Anyway, I thought I had a good picture of the unit in the attic, but I don't. I'll attach the picture I do have and see if the numbers are legible. At any rate, the model number is RBEH 17J14SFAA and the serial number if T M4800 02564. And it has an Aprilaire 2200 air filter system.
And that's about the size I would expect. It only has to heat and cool about 1,295 square feet.
/ heat pumps #35
Thanks Techman, you had me worried there. I know I did have a problem finding one that was specifically for heat pumps, and it did cost about twice what a "regular" digital thermostat cost.
As an aside, my family can't or won't figure out how to reprogram it. So I've got the temp set really low in my house this winter and am saving some real money. One of my coworker's had an electric bill that was over twice as high as mine, and his house is smaller. Problem is, he has a manual thermostat and the kids figured out how to work it. . . :)
So maybe not the way the savings are supposed to happen, but I'm saving none-the-less.
/ heat pumps #36
Did you ever notice how many businesses have a lockable cover over their thermostats to keep employees from messing with them? When I was gainfully employed, I've even had to give some of my employees an emphatic direct order to never touch the thermostat for any reason. It never ceased to amaze me how many people think if it's 73 in the room and they want it at 70, they need to turn the thermostat to 60 to get it to cool off quicker.:eek:
Our house has a Robertshaw 9620 digital programmable thermostat "7 Day Programmable 2 Heat / 2 Cool". Since I didn't know how to work it and couldn't find a manual in the house when we bought the place, I went on the Internet and found and downloaded a manual. Quite some time later, I found the original manual on top of the water heater.:rolleyes: But I guess all that "programmable" stuff is wasted because we have it on manual, set the temperature for the Winter and won't change it until we change to cooling.:D
/ heat pumps #37
In Louisiana?!?
I wouldn't need anything more than a T-shirt if I lived that far south. Being covered with an insulating layer of blubber, such as I am, takes a lot of the edge off those drafts.
/ heat pumps #38
Maybe a stupid question... but how do large buildings heat in this cold weather... ie airport terminals, large box stores etc. Was at Dullas and Detroit airports about two weeks ago and they were warm. Huge areas to heat.
ask the chief
mark
/ heat pumps #39
ask the chief
mark
Really big buildings don't have to heat. Many air condition year round. The heat generated by lights, equipment, and people is enough to heat the building.
/ heat pumps #40
ask the chief
mark
Some use very very large boilers
2006 PETERBILT 379 (INOPERABLE) (A67714)
2006 PETERBILT 379...
2016 KUBOTA SVL75-2 SKID STEER (A65056)
2016 KUBOTA...
John Deere 6420 (A64911)
John Deere 6420...
2018 JOHN DEERE 331G SKID STEER (A65056)
2018 JOHN DEERE...
2017 Ford Explorer SUV (A66738)
2017 Ford Explorer...
2001 Generac SG0060 75kVA Natural Gas Generator (A66734)
2001 Generac...
