LD1
Epic Contributor
Bill still seems pretty high for a ~1700kwh usage average. That would equate to a ~$190 bill up my way
Back to air conditioning: I bought this 13 SEER used, 3 ton; replacing a old 4 ton, straight cool/heat strips. I did not wire in the auxiliary heat (seem to remember needing more wires in T-stat wire?). He said that if the auxiliary heat isn't hooked up, it causes problems with defrost...
If you are using straight cool and heat strips for heat..You aren't using the H.P. at all.. You have the AUX heat ( heat strips) wired in ,and only using Aux. heat (heat strips). for heat. You won't have any defrost issues, because you aren't using the HP. This is probably why your bill is high . HP is primary heat.. heat strips are Aux .heat
