Never had one done, so I cannot help there.
Those 250-325 bills, what is the usage? Electric rates vary ALOT across the country. Usage tells me alot more than cost.
I don't get paper bills from Clay electric co-op, but the guy said high was 48 kwh/day over last 6 months. His first comment was, why does your bill stay so consistent? He said January should be roughly double November's usage, but they where nearly the same. He also said I'm averaging 44 kwh/day for first 11 days of this cycle; even though we just had some brutal cold (below 20'F). I have just replaced my well pressure switch (I need to start a separate thread for advice on that).
He was very realistic, said you really can't upgrade your insulation, and the best thing is a metal roof, but that's $6000+, and not something you do to save money short term. His major point was possible hot water leaks under the house. I had no idea how much hot water costs; but he said up to $350/month from a "pee" stream.
Said the heat pump was drawing at what it should ?1000w/ton?
So this weekend, guess I'm getting under the house looking for leaks. My soil perks very well (we had 7" of rain in one day, and no standing water in the ditch 2 years ago) so leaks won't lead to wet spots visible from outside the home.
Back to air conditioning: I bought this 13 SEER used, 3 ton; replacing a old 4 ton, straight cool/heat strips. I did not wire in the auxiliary heat (seem to remember needing more wires in T-stat wire?). He said that if the auxiliary heat isn't hooked up, it causes problems with defrost...
Now way off from A/C: I have a 220v submerged pump. I had problems with pleasure switch about 2 years ago; one contact had gotten scorched when a suicidal bug got in it... so as an emergency repair I stuck a small piece of a beer can between that One contact. The other side worked fine... well; two years later I have finally gotten around to replacing that short term fix. With 1 leg of the 220v broken, no current should have flow... right? There is of coarse no neutral, only two hots...
