heat pump oops...
/ heat pump oops... #1
rockyridgefarm
Elite Member
NEOklahoma
Yanmar YT347
I goofed.
Lat fall, my A/C was acting up. I had wanted to get a package unit, anyway, so I decided to replace it with a heat pump. My heat and air guy was out of town, he usually lets me do what I can and finishes thing up. But this is a package unit, so I ordered one and hooked it up myself.
It wasn't working right, so I call him out. he said the compressor wasn't starting, so he put a hard start device on it. Well we had a mild winter, and it wasn't till summer that I realized i still have no compressor. And no heat and air guy either, I think he moved to mexico.
I call the vendor that I got it from. Well, they nicely send me a new compressor. No labor though. And I get quoted $500 to change it. Plus filters.
Shheesh. I gave $1500 for the heat pump. Is there no way to get the manufacturer to warrant the labor?
I guess I get to pay to have my heast pump fixed...
/ heat pump oops... #2
Some brands let dealers sell a parts & labor warranty.Some brands will sell the homeowner a labor warranty up to a dollar amount .If this doesnot apply to you,then they won't pay labor. Most places I do business with won't sell to you unless you are a dealer.I'm suprised that any supply house would sell you a unit unless you are certified,they are strick around here with all the Government regulations on the sale & use of freon.If you have the equip. to remove the freon, it shouldn't be to difficult for you to replace & recharge. Good luck to you.
/ heat pump oops... #3
I do my own. I thought $200 was high to swap out a compressor. Of course, I have four package units, four split systems and a whole bunch of window units to maintain. I've also started working on my refrigerators, too. I only put up with being bent over for so long before I find a way around it. /forums/images/graemlins/mad.gif
/ heat pump oops... #4
I would say that if you don't have the tools and experience to reclaim the existing refrigerant, replace the compressor using a torch, add a liquid line filter, test the system for leaks, evacuate the system, and weigh in the new charge then you should leave the job to a professional, least you might be doing it yet again.
/ heat pump oops... #5
And depending on the old compressor, flush the system b-4 installing new compressor.
/ heat pump oops... #6
Are you really sure the compressor is bad ?
There can be several reasons the compressor is not running besides a bad compressor.
Ben
/ heat pump oops... #7
Mike,
Am I allowed to paste here my reply to you from you private message?
Or I guess you could paste it in here if it would help others with policy.
murph
2007 Peterbilt 378 (A62679)
2007 Peterbilt 378...
APPROX (80) PIECES OF 48" X 56" EXPANDED METAL (A64280)
APPROX (80) PIECES...
Timpte 720 All Aluminum 7000 Tilt Trailer (A63689)
Timpte 720 All...
40' Used Container, High Cube, Single End Doors  (A62679)
40' Used...
2005 C7500 20' Box Truck (A62613)
2005 C7500 20' Box...
KOMATSU FG25T-12 WAREHOUSE FORKLIFT (A64276)
KOMATSU FG25T-12...
