Heads up for Kioti guys with cabs and non-functioning electrics.
   / Heads up for Kioti guys with cabs and non-functioning electrics. #11
In my case I didn't need the shop manual, just good ole' reasoning and knowing how the circuit worked. Those were the original relays.
The fuel solenoid relay went out about 5 years ago and it sure was cold out when it quit. Fixed that problem in my Shelter Logic tent.
Call me cheap if you want but the trip to the dealers is $400.oo each way. He is about 150kms/90 miles away.
How expensive is gasoline up there if 90 miles takes 400 dollars?
   / Heads up for Kioti guys with cabs and non-functioning electrics. #12
   / Heads up for Kioti guys with cabs and non-functioning electrics. #13
The two relays with the yellow tags. I could very gently wiggle the connections and the radio cut out just like when I was operating the tractor. Those relays change the circuit for the speakers between the radio and the acc jack. The acc jack goes into an amplifier that is just below the acc jack. The radio and acc jack both still sounded bad after cleaning the contacts. So I ran new wires directly from a new radio to new speakers - problem solved. And I don't need the acc jack because the new radio connects to my phone to stream music.
I know this is old, just wanted to say thanks for sharing the photo and explanation!
My 2021 CK2610SE has been driving me crazy with both speakers cutting in and out randomly, and I knew it had to be something common to both radio and aux modes. I found those 3 small relays through the stereo opening, so I got close! I bet my problem is the exact same as yours. Finding your post will probably save me a lot of time!
2018 Ford Explorer AWD SUV (A59231)
2018 Ford Explorer...
8ft Flatbed Truck Body with Axle (A55851)
8ft Flatbed Truck...
2022 Brush Wolf ALPHA-XP Skid Loader Brush Cutter (A56438)
2022 Brush Wolf...
2005 GMC Canyon (A57148)
2005 GMC Canyon...
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
