Headlight switch... pictures?
/ Headlight switch... pictures? #1
ChipSmith
St. Leonard, MD
Cub Cadet GT2550
I want to install a switch for my headlights so they are not always on. I know some of you have already done this modification, so do you happen to have any pics? I am interested in what kind of switch you used, where you mounted in and how you spliced it in. Thanks!
/ Headlight switch... pictures? #2
i have done this. i just tied into the headlight hot wire in the main wire harness. and i mounted a little yellow rocker switch that lights up when its on to the left of the steering wheel. i will try and take some pics
I am planning to tie into the "headlight wiring harness" right before it connects to the main wiring harness. Cub sells the headlight wiring harness separately for around $9 so it wouldn't be as bad to replace just that part of the harness, if need be. That connection is on the right side of my GT2550 so I was thinking of mounting the switch on the right side of the dash, somewhere around the ignition switch.
As for the switch, I've been looking at these rocker switches. Specifically #66-2286 because I think it would look more like a factory install than an afterthought. My only concern with that particular switch is the size of the whole (0.80") required to mount it. The other one I like is #66-2281 and it only requires a 1/2" hole, but I think it would look like more of an add-on. Both of these switches have a blue LED that illuminates when on. The LED's come is various colors, but I thought blue would be a good color for the lights, kinda like the high-beam indicators on most cars.
Anyway, I'd love to see some pics.
/ Headlight switch... pictures? #5
Thanks for the link. I ordered the 66-2286 yesterday. $7 with shipping. I too was looking for a switch that didn't look like an afterthought.
/ Headlight switch... pictures? #6
the wires and switch im pointing at is what i did.
Thanks for the pics. Nice job!
Anybody else what to show off their handiwork?
/ Headlight switch... pictures? #8
This is switch # 66-2286
/ Headlight switch... pictures? #9
IHCUB,Looks great! Where did you find the switch?Thanks cubbybob
/ Headlight switch... pictures? #10
Man, that switch does look factory....nice. :)
I just used what I had available, I may yet change it around again anyhow. The switch on the left is the headlight switch. I just ran a ground wire through the factory harness and cut the ground to the lights near the end of the harness and connected to mine.
/ Headlight switch... pictures? #11
thanks. i picked it up at auto zone it came with 3 different color lenses. i used the amber one it matched good.
2005 Peterbilt 379 Extended Day Cab (A62613)
2005 Peterbilt 379...
2020 INTERNATIONAL LT625 48" SLEEPER (A62613)
2020 INTERNATIONAL...
2014 Bobcat T650 (A60462)
2014 Bobcat T650...
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A64279)
2018 JOHN DEERE...
Muck-Truck Wheelbarrow (A61567)
Muck-Truck...
2012 Dodge Ram 1500 4wd (A62679)
2012 Dodge Ram...
