headache rack for pallet forks
  • Thread starter washita
  • Start date
   / headache rack for pallet forks #1
W
washita
Guest
what is a good size for a ''headache'' rack for pallet forks on the 425 series. going to fabricate one for my forks just unsure how tall or wide to make it. thinking of using a slip in style configuration to ease removal if neccessary and possible other options ie: boom pole. suggestions ? ideas?
   / headache rack for pallet forks #2
Mine is 42". It's 5000 lb. rated and on an 100hp ag tractor though. I guess what you are planning to pick up with it (height of the load) and if it is bundled or loose material should guide you to an appropriate height.
Kim
   / headache rack for pallet forks #3
What is a headache rack?
   / headache rack for pallet forks #4
bars to keep the load from slipping through to give you a headache...so named from the back of flatbed trucks where the load might go through the back of the cab...
All the best,
Peter
2016 Ford F-250 4x4 Crew Cab Pickup Truck (A55852)
2016 Ford F-250...
2007 Ford E-450 Super Duty 16ft Portable Command Center Office Truck (A55852)
2007 Ford E-450...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
Hilti TE 2000-AVR Electric Jack Hammer (A55973)
Hilti TE 2000-AVR...
John Deere 2640 2WD Tractor with 146 Front Loader (A57024)
John Deere 2640...
2009 Yale Veracitor 135VX 12,150lbs Straight Mast Forklift (A56857)
2009 Yale...
