Head gasket on 1500
   / Head gasket on 1500 #1
klawson44
Virginia
Whats the ballpark on the dificulty and the cost of replacing a head gasket on a 1500? Any thoughts $$ estimates would be great, Thanks..
PS Slight blow-by and discolored/milky oil, the tractor runs/sounds good and does not smoke even under load..
   / Head gasket on 1500 #2
You may also have to cosider having the head/block planed if required which will add to the cost. No idea on cost factor as asked in your question.
Egon
   / Head gasket on 1500 #3
Porkchop, I replaced my headgasket on my 2310 last spring. Cost about $200 including; parts, oil, antifreeze and getting the head shaved at Carquest. It is not any more difficult mechanically than a four cyl car motor and alot more accessable. The only hard problem was bleeding the fuel system to get the engine to start. That actually took longer than the rebuild. You need to bleed the fuel line to the fuel filter then the injector pump and then each line to each injector. THis is not diffucult to do, just very time consuming for the first time and frustrating because until it started I didn't know if I was doing the right thing. Got my parts and alot of advice from Len Sheaffer( thanks again). I'm sure your dealer probably could do the same if he handles parts. Also other dealers on this board who handle parts would be willing to help. If you do not have the repair manual for the YM155 I would suggest buying it. The book was very helpful and answers alot of questions.
   / Head gasket on 1500 #4
Is the head made from aluminum and the block cast iron on yanmars?
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55852)
2006 iDrive...
UNUSED RAYTREE RMT48-48" HYD TRENCHER (A60432)
UNUSED RAYTREE...
(16) WOOD PALLETS (A60432)
(16) WOOD PALLETS...
FUTURE 60" PALLET FORK (A60432)
FUTURE 60" PALLET...
2012 FREIGHTLINER CASCADIA SLEEPER (A59905)
2012 FREIGHTLINER...
2018 FORD F-150 XL EXTENDED CAB TRUCK (A59823)
2018 FORD F-150 XL...
