Mowing HD60 Mid Mount Mower doesn't install correctly
/ HD60 Mid Mount Mower doesn't install correctly #1
DBAugie
MIDDLEBURG, VA
JD 1025R
JD 1025R, HD60 mid mount mower.
Reading the manual (OMLVU26521 H2), I follow all the steps.
All works fine until it is time to lift the mower and set the height adjustment. Then it becomes clear that the rear lock tab is not seated against the rear lift arm rod. In fact, the rear lift arms are NOT fully engaged in the rear lock assembly. Of course, the front draft link pivot pin is not fully engaged in the front support hangers. Repeated attempts to get this task done have been unsuccessful, if not entertaining.
Does anyone have experience with this kind of problem?
I've been at this for four days, on and off. Tomorrow, Monday, I'll call the dealer and see what they have to say.
/ HD60 Mid Mount Mower doesn't install correctly #2
At the front of deck. The bar that hooks to front of tractor. Are the nuts even? Like same distance down in threads? Send a pic if you can. Start with backing them to the very end and install deck. Seat it all the way on. Where tab will flip up and lock. Then you need to adjust the nuts on the front. You want about a small washer gap from back of bar to the inside hook part in tractor. You understand what in talking about ??
Yes, I understand.
I'll give it a try.
Thanks!
So, I ran out the nuts on the front draft link.
Try as I might, I cannot get the mower deck to seat in the fully locked position. IMG_0687.JPGIMG_0686.JPGIMG_0685.JPGIMG_0684.JPG
/ HD60 Mid Mount Mower doesn't install correctly #6
Hmmm is it going in to gearbox correct in center? Something isn't lined up right.
/ HD60 Mid Mount Mower doesn't install correctly #7
Is the deck wheels all the way up and deck hard in ground? Is the arms all the way down for install under tractor?
Deck wheels are all the way up. The front of the mower deck is plowing a nice, narrow, farrow in the blue-stone drive way.
The arms are all the way down and the blade height control is in the "Install" position.
At least the sun is shining and the birds are chirping.
/ HD60 Mid Mount Mower doesn't install correctly #9
Lol man I'm trying to think of all the steps and I believe we have covered it. Hmmm it's something and I'm thinking .... it's probably something very simple but I don't know what ....
On top of the mower deck, in front of the gear box, is a ?spline? ... a slotted shaft that is supposed to fit into the receiver of the mid-mount PTO. Is that shaft supposed to fit all the way into the receiver? When I look at it from underneath the tractor, it appears to be only two thirds of the way inserted. There doesn't appear to be any obstructions in/on either the male or female ends, but I've never looked there before and I cannot say for sure that it is correct.
In any case, I'll call local dealer tomorrow morning and get an appointment to get it repaired ... and maybe an extra 10-15 minutes for customer (that's me!) orientation and training.
I'll let you know what I find out.
/ HD60 Mid Mount Mower doesn't install correctly #11
There is a way to adjust the part in tractor that receives the male spline. The bolt on back side. It should side parallel to ground when dropped all the way. You may adjust bolt in or out if it isn't. Should tell you about it in owners manual
/ HD60 Mid Mount Mower doesn't install correctly #12
I have yet to hook up my MMM, but I do recall reading somewhere that when you hook it up, make sure the PTO selector switch is not set to the Mid PTO. Apparently if is is set to the Mid PTO, the PTO won't move and may not hook up correctly. Just a thought. Good luck.
OK! Here's the answer:
In the front of the tractor are the front support hangers. Essentially, they are two slots that the front draft link pivot pin slides into. When the pin is all the way in the two slots, the rear lift arms are all the way in the rear lock assembly.
In this case, the right-hand front support hanger was bent! The bend prevented the pivot pin from sliding all the way back. The local dealer's repair guy was able straighten the hanger out with really big crescent wrench.
Now the mower installs correctly under the tractor.
/ HD60 Mid Mount Mower doesn't install correctly #14
Good. I knew we where taking the rights steps. But yea a bend up there will definitely throw it off. Good deal glad your fixed up
(8) Massey Ferguson Tractor Suitcase Weights (A65640)
(8) Massey...
Cattle Feeder (A65640)
2023 Kubota Z232 (A64127)
2023 Kubota Z232...
New/Unused Quick Attach Backhoe Attachment (A65583)
New/Unused Quick...
275 Gallon Cage Tanks, Koser Safe, with 2" outlet (A62679)
275 Gallon Cage...
3'x8' Stack of Sheet Metal (A64127)
3'x8' Stack of...
