Hazard lights blow fuse on Boomer 45
   / Hazard lights blow fuse on Boomer 45 #1
BlueRidgeFarm
New Holland Boomer 45
With the ignition off my hazard lights work normally. When the ignition is on (with engine either running or off), turning on the hazards immediately blows the fuse, disabling the ignition. It’s only blowing the 10amp hazard fuse. Any suggestions where I should start to look would be much appreciated. Also how is the switch removed from the panel? There is a plastic surround, but it doesn’t seem to want to move.
Thanks very much,
Gavin
   / Hazard lights blow fuse on Boomer 45 #2
What happens if you use the turn signals? You got a short to ground somewhere. Otherwise the fuse wouldn’t blow.
1986 Peterbilt 359 Truck, VIN # 1XP9D29X9GD196948 (A51572)
1986 Peterbilt 359...
1999 KENWORTH T800 DAY CAB (A53426)
1999 KENWORTH T800...
2020 KOMATSU PC360LC-11 EXCAVATOR (A51246)
2020 KOMATSU...
2015 FREIGHTLINER SPRINTER VAN (A52576)
2015 FREIGHTLINER...
Electric Concrete Mixer (A51573)
Electric Concrete...
2015 GMC SIERRA 2500 SERVICE TRUCK (A52576)
2015 GMC SIERRA...
