Hazard lights blow fuse on Boomer 45
   / Hazard lights blow fuse on Boomer 45 #1
BlueRidgeFarm
New Holland Boomer 45
With the ignition off my hazard lights work normally. When the ignition is on (with engine either running or off), turning on the hazards immediately blows the fuse, disabling the ignition. It’s only blowing the 10amp hazard fuse. Any suggestions where I should start to look would be much appreciated. Also how is the switch removed from the panel? There is a plastic surround, but it doesn’t seem to want to move.
Thanks very much,
Gavin
   / Hazard lights blow fuse on Boomer 45 #2
What happens if you use the turn signals? You got a short to ground somewhere. Otherwise the fuse wouldn’t blow.
2025 New/Unused Wolverine Pallet Fork Frame (A51573)
2025 New/Unused...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
2008 OVERLAND TANK KILL TRAILER (A52472)
2008 OVERLAND TANK...
2014 COTTRELL CX-09LS2 AUTO HAULER (A52576)
2014 COTTRELL...
2025 New/Unused 72in Skid Steer Sickle Bar Mower (A51573)
2025 New/Unused...
