Hazard lights blow fuse on Boomer 45
   / Hazard lights blow fuse on Boomer 45 #1
BlueRidgeFarm
New Holland Boomer 45
With the ignition off my hazard lights work normally. When the ignition is on (with engine either running or off), turning on the hazards immediately blows the fuse, disabling the ignition. It’s only blowing the 10amp hazard fuse. Any suggestions where I should start to look would be much appreciated. Also how is the switch removed from the panel? There is a plastic surround, but it doesn’t seem to want to move.
Thanks very much,
Gavin
   / Hazard lights blow fuse on Boomer 45 #2
What happens if you use the turn signals? You got a short to ground somewhere. Otherwise the fuse wouldn’t blow.
Chevrolet C8500 Flat Bed with a Moffet Kit (A52748)
Chevrolet C8500...
New Holland Boomer 55 Tractor (A52384)
New Holland Boomer...
NEW Wolverine Skid Steer Vibratory Roller (A53002)
NEW Wolverine Skid...
2021 Kubota RTV-X1140RL-A (A47384)
2021 Kubota...
CONTACT INFO (A53084)
Guard Rail Joints (A51692)
Guard Rail Joints...
