haybine
/ haybine #1
Anonymous Poster
Epic Contributor
Has anybody run a haybine with a compact tractor? What would be the minimum horsepower for a eight foot model to work properly? Thanks for any comments.
/ haybine #2
Most all haybines require 30 pto horsepower. The only thing to worry about is if your have hills as they are out to the side and will throw a tractor around if on step hills and to small tractor is used.
/ haybine #3
Bruce, Art probably knows more about this than I, but John Deere's web site for their 7' 9" (model 710) says is weighs about 3180 pounds and calls for "35 PTO hp or larger". That's the smallest one they list. I believe the 9' Gehl that I've used called for 50hp. You might be able to do the job with a smaller tractor, but you probably wouldn't like it.
Bird
/ haybine #4
I wouldn't do it with a compact tractor and I do everything with mine. I tryed it on a 9 foot model and it was a no go. This was a brand new one as well. I know you said 8 foot but I don't think I could have handled an eight foot one either. I can run the rake and square baler no problem but need the massey for my haybine, 9 foot.
/ haybine
Your PTO HP is only part of the equation... your tractor weight is another...
Even a 3800 lb. tractor with 60 PTO hp {I'm sure someone has one /w3tcompact/icons/smile.gif} would be a struggle with a 3300 lb. haybine...
It's like the "tail wagging the dog" or have you seen a can do everything Toyota 4WD Tacoma towing a 24' Cruiser Boat up a mountainside or steep grade...
You just need a little more "umph" to tow something that heavy versus a semi-light weight compact tractor.
/ haybine #6
My Case DC is rated in the mid 30 (HP wise) Normally a baler, rake, cutter-conditione, 3 bottom plow,or 8' disk is no problem for it, but it was really struggeling with a 8 foot haybine. Tractor weight was OK (4600 Lbs) but PTO just didn't have it. I would guess something with 45 HP would be minimum if you want the tractor to last.
Steve
2014 KENWORTH T370 ROAD TRACTOR (A62130)
2014 KENWORTH T370...
UNUSED AGT ATK-B1000 TWO-POST CAR LIFT (A64281)
UNUSED AGT...
211298 (A62131)
211298 (A62131)
2018 Ford Escape SUV (A61574)
2018 Ford Escape...
2016 BOBCAT E35I MINI EXCAVATOR (A62613)
2016 BOBCAT E35I...
1000 GALLON FUEL TANK (A64276)
1000 GALLON FUEL...
