Hay Storage
/ Hay Storage #1
Scoutman
Huntsville, AL
Yanmar 2210
New member here. Just bought a Yanmar 2210 last week and picked up some round bales for our 2 horses for the winter. I'd like to know the best way to store these. The plan was to put them under a tarp and possibly put them on pallets to keep them off the ground. Any other good suggestions other than building a barn to store them in the dry? :D
Thanks
/ Hay Storage
I'm only talking about ~8 bales here so I'm working on small scale
/ Hay Storage #3
In the past I used blue tarps and stacked them on pallets. It worked OK
/ Hay Storage #4
Thanks
You can pick up plastic sleeves special made just for sliding over the rolls. Ken Sweet
/ Hay Storage #5
a heaver duty tarp will make the biggest diffrence. Call around to the bilboard shops and see what they are getting for old signs. they are high quality "tarp" material.
/ Hay Storage #6
I'm using tarps and pallets, and the horses seem to be staying fat enough.
/ Hay Storage #7
I try to stay away from tarps as they trap moisture and trap it close to the bales causing them to mold. If you use a tarp put something across the top of the bales to give it breathing room and keep the tarp a foot or so off the ground to allow for air cirulation. I have seen many hay get ruined by tarping them wrong.
/ Hay Storage #8
I don't keep any hay, but around here I usually see round bales lined up by the fence in a corner of the pasture. I don't recall seeing any tarps or anything more than net wraps on them (though I don't know if that'd be different if we weren't in the midst of a multi-year drought).
/ Hay Storage
Wow, thanks for the responses. I put a tarp over them on the trailer last night to keep them dry from the showers we're supposed to get tonight. Should have bought a bigger tarp though. I have a pole canopy that I wasn't crazy about using but after talking to my wife last night I think we have a place we can put it that won't be too visible from the road and that the horses won't mess with. I will lay some pallets down in it and put the bales 2 wide and 5 deep for a full house. When I don't have hay in there I can always store a Jeep or the tractor in it. It's 10 wide, 20 deep, and 12 high.
/ Hay Storage #10
Keeping a bale off the ground and dry will save you about 20% of the bale,, that about how much you lose just setting them outside in the elements.. They did a study on it at Texas AM I was surprised how much hay lost was on a round bales when stored outside on the ground,,
/ Hay Storage
Yea I had seen a number of studies by various sources on hay efficiency regarding storage and hay rings/feeders. We're using a borrowed cattle ring feeder turned upside down at the moment. I'll have to get our own horse ring before too long but at least we're not having to deal with square bales every day or so.
/ Hay Storage #12
Leaving round bales out in the rain won't hurt them as much a rain on a square bale would. The outer layer on the bale acts like a thatched roof but you still loose about 20% from leaving them out.
/ Hay Storage #13
If you have any old bed liners from pickups you might be able to cover two with one. I use one on a skid of wood that sits beside the basement window until used up then I bring another from storage.
/ Hay Storage #14
They did a study on it at Texas AM,
Lou
Do you know how many Aggies it takes to pop Popcorn??? One Aggie to hold the popper and two(2) Aggies to shake the stove!!!!!!:drink::drink: In all seriousness getting rd bales off the ground saves hay as does Netwrap.
/ Hay Storage #15
Same amount to change a light bulb.. one to hold the bulb and two the turn him.. Hey we maybe on some here,, three Aggie and save hay.. lol..Lou
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
3268 (A63117)
3268 (A63117)
2019 JOHN DEERE 331G SKID STEER (A65053)
2019 JOHN DEERE...
2024 JOHN DEERE TURF GATOR (A63276)
2024 JOHN DEERE...
2021 UTILITY VS2DX 53X102 T/A DRY VAN TRAILER (A67148)
2021 UTILITY VS2DX...
2018 Tycrop Vector Belt 22ft. VB-16H Portable Sand Belt Conveyor (A64194)
2018 Tycrop Vector...
