Hay stacker
/ Hay stacker #1
Saskfarmhand
Im looking at buying a nh stackliner 1000. Anyone know what kind of hp it requires to run well. It does stacks of 55. Also are these dependable machines. Just bought a 316 square baler and I think this will save alot of time and energy.
/ Hay stacker #3
It actually takes very little tractor horsepower (Running a hydraulic pump is just about all the pto really does), but the tongue weight is VERY big. The fully loaded weight can be large, too. I run a 1012 (with unload ability) and its a big labor saver for me. It carries 8 bales per layer and 7 layers on the back rack. (=56). Plus, you can carry and extra 8 on the first table without raising it for a total of 64 out of the field (and maybe 2 more on the tray. Then manually unload the 8 on the first table and dump the rest. I added a 1-way cylinder to the chute pickup to shake a bale that sticks once in a while on a sidehill or for some other reason. Convenient for road travel, too or just getting the rig thru a 12' gate without dismounting from the tractor. I also added a caster wheel on the chute to follow the ground line. Put the chute cylinder in float mode and it hugs the terrain for easy pickin's.
They are a little finicky as to adjustments of the second table drop point and you will need to adjust the baler to set bale length to a required amount. If yours has push-off feet (used to push the wagon+stacker combo away from the stack when unloading), make sure they are well lubed and adjusted, because bending them when lowering the 2nd table will ruin your day.
/ Hay stacker
Thanks guys. I thought i could run it fine. I was worried about the weight issuse. Dont wanna snap a hitch with a load on. I have a smaller tractor only 35 hp so ill probably have to do by hand until i get a bigger tractor.Rats
GENERAC 80KW PTO POWERED GENERATOR (A64278)
GENERAC 80KW PTO...
2008 MACK CHU613 DUMP TRUCK (A63569)
2008 MACK CHU613...
T/A Drop Deck Equipment Trailer (A64556)
T/A Drop Deck...
2017 Dodge Charger Sedan (A64557)
2017 Dodge Charger...
2002 Pace American of Texas Trailer, VIN # 47ZA528212X020330 (A61572)
2002 Pace American...
2016 Dodge Charger Sedan (A64557)
2016 Dodge Charger...
