Hay rakes
   / Hay rakes #1
xmariner
Bushnell, FL
LS XR4155HC
I know this is a matter of personal preference but I'd like to "hear" your thoughts on wheel hay rakes vs rotary rakes. I realize that wheel rakes can come in very large configurations for obvious reasons.
We hay between 8 and 15 acres so it's small enough to consider both.
Thanks
   / Hay rakes #2
What you growing? What type rotary rake you looking at? I have the WR22 and wish would have gotten the Kuhn speed rake or like.
   / Hay rakes #3
I learned the hard way that you REALLY have to look at the potential for breakdowns. Get the most simple, high quality tool that you can afford. I started with a rolabar rake, and I've sunk a good bit into it, just in u-joints and rubber teeth. And still had it fail while taking, with a storm coming. I hear that the rotary rake doubles as a tedder. While it sounds like a good idea, I think it's better to have that as 2 separate tools; if I'm using my tedder and it breaks, I still have my rake to finish up the job.
   / Hay rakes #4
I've never had a "wheel rake", but did own a very old IH No. 5 side delivery and that thing roped the hay. I bought a Morra rotary from Agri-supply and really like the fluffy wind rows it made. I tried to ted with it and it still gpt kinda of a wind rowed. My vote is for the rotary rakes. bjr
   / Hay rakes #5
We use a wheel rake on 70 acres of coastal bermuda hay. JD 10 wheel rake which is a really a Tonutti. Simple and inexpensive piece of equipment.
   / Hay rakes #6
I'm using a IH16. Doesn't seem to rope the hay. Had to replace a couple of bearings and some teeth but otherwise pretty good rake
   / Hay rakes #7
I like the parallel bar like the JD 600 series. Just work for me regardless of the crop. However, I don't do the work that makes the wheel rakes popular so you have to factor that into my answer too.
   / Hay rakes #8
I've always been curious about a rotary rake. I got the chance to bale behind one and hated it. I'm used to a v-rake which makes the windrow the same width my baler is so I don't have to drunk bale, I just follow the windrow. The rotary rake did a good job as far as cleaning the ground but made a narrow windrow that required side to side baling.
My opinion the only rake to have is a v-rake.
   / Hay rakes #9
I've only been around a to rolabar rake and a wheeled v-rake. The v-rake can be set for baler pickup width and takes the stress off the baler driver. Makes a nice fluffy windrow. The rolabar (NH & IH) did good jobs but seamed to leave a lot unless you really run the teeth in the dirt. Even with no missing teeth. Both rakes seamed to rope the hay. NH not as bad but they do. 256 & 258. Plus with the rolabar to rake doubles for a round baler you have to out run the baler. With the v-rake it's pass for pass.
1990 INTERNATIONAL 3800 DAY CAB DUMP TRUCK (A58214)
1990 INTERNATIONAL...
Forklift Telescopic Boom W/11ft Extension (New/Unused) (A59225)
Forklift...
Ford 3000 Tractor (A57453)
Ford 3000 Tractor...
2147 (A58376)
2147 (A58376)
2018 HINO CONVENTIONAL TYPE TRUCK (A58214)
2018 HINO...
2016 PETERBILT 365 (A58214)
2016 PETERBILT 365...
